David Gouk Race Engines
Bosch K3 Vs Valeo Alternator
Hi Folks,
I am looking at buying a new Alternator to suit my early 901 fan ring, Should I step up to the bosch K3 unit or will the cheaper valeo unit do the same job for less money? Your thoughts please. Regards David |
Valeo replacement ok then?
muck-raker
You may seriously want to consider taking your old unit into an electrical shop that does rebuilds. There are many threads about this, and the general consensus is that our alternators are basic, nothing special, are simple to rebuild, and you will save a stupid amount of $$$$. Just sayin'
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
RETIRED
Local rebuilds are better than a no name supplied by whomever. They may give you a life warranty but doing another r&r would suck.
Have it done right the first time.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
83 911 Production Cab #10
[QUOTE=Joe
Have it done right the first time.[/QUOTE] +1 Bought a cheap rebuild, VR went South, boiled the battery and spend a day to removed and put a new one VR in ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
the new bosch versions arent german made and are no better than the Valeo. I got a new valeo (not reman) and it seems to be fine.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
ASE Master Tech - 35 yrs
valeo is fine choice
i put a valeo in my 914-6 last summer - "one-wire" style internally regulated - no external regulator needed
wish i'd had it years ago one caveat - the wiring diagram that came with it was WRONG - cost me a day's work to pull it backout & fix it after the eBay "TopSeller" in SoCal coughed up the correct diagram
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
"I got a new valeo (not reman) and it seems to be fine."
Right, until it starts to overcharge! "i put a valeo in my 914-6 last summer - "one-wire" style internally regulated - no external regulator needed wish i'd had it years ago" Again, until when you have to change the regulator because of overcharging and wish you still had an external regulator.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
So then upgrade the regulator. there are several brands you can buy if I recall. the most expensive one i could find was less than $30. I dont recall the brand.
"So then upgrade the regulator."
Doesn't solve the problem that internal regulators are less reliable than external ones, i.e. the heat exposure of the internal, and are much easier to replace.
Do those even fit? I would be concerned that any modern unit would be too thick and require the later fan ring. Maybe Valeo is making one with the same dimensions as the original 35A Bosch.
I am on record here as despising internal regualtors. There is no good electronic reason for them, and the heat and vibration of the location in a 911 is not good for them at all.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
