Weber bits
In Wayne's 101 book he talks about bits for Webers not being readyily available unless they are stripped form old carbs. Anybody know where I can get bowl drain plugs, mine are cracked, and some air mixture screws. Are these common parts across other models, Is there somebody making replacements? Thanks
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 04-03-2002, 04:59 AM
http://www.webercarburetors.com/
http://www.piercemanifolds.com/yourwebers.htm
http://www.webercarbs.com/
http://www.weber-carburetors.com/
Old 04-03-2002, 05:04 AM
Wayne, I just gotta ask thre question, I've seen you refering to PMO before. Who are they or what is it?
Steve F
69 911
71 911
87 Carrera
Old 04-03-2002, 02:17 PM
Hey, I've been wondering this for a while, and it seemed appropriate to the thread -- I'm wondering why all photos of carbs show tennis balls or covers on them. I understand that this is to block things from entering the carbs, but what about when driving? wouldn't there be a likelyhood of debris entering the system then? or is this just a safeguard against the more obvious nut, bolt, wrench-type things from falling in?
Pardon the ignorance.
Jared
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 04-03-2002, 02:20 PM
Weber no longer makes 40IDA carbs. PMO took the Weber design and improved upon it and sells 40, 46 and 50mm versions of the "IDA" - $2100-$2300 per pair. They also have ported manifolds, linkage, parts, etc. They don't have a website as far as I know. Here's the contact info:
FAX: 310-394-6313
135 17th St.
Santa Monica, CA 90402
The tennis balls? Used just like you said, but in race cars without air filters over the velocity stacks. -- Curt
Old 04-03-2002, 02:43 PM
