Weber bits
In Wayne's 101 book he talks about bits for Webers not being readyily available unless they are stripped form old carbs. Anybody know where I can get bowl drain plugs, mine are cracked, and some air mixture screws. Are these common parts across other models, Is there somebody making replacements? Thanks
Steve F 69 911 71 911 87 Carrera 2004 RAM 1500 4x4 "Hemi" |
Author of "101 Projects"
Let me know if any of these places has a good stock on IDA 3C parts. Most of them are still scrounging around, and I have yet to find a good source besides PMO...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne, I just gotta ask thre question, I've seen you refering to PMO before. Who are they or what is it?
Hey, I've been wondering this for a while, and it seemed appropriate to the thread -- I'm wondering why all photos of carbs show tennis balls or covers on them. I understand that this is to block things from entering the carbs, but what about when driving? wouldn't there be a likelyhood of debris entering the system then? or is this just a safeguard against the more obvious nut, bolt, wrench-type things from falling in?
Pardon the ignorance. Jared
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Weber no longer makes 40IDA carbs. PMO took the Weber design and improved upon it and sells 40, 46 and 50mm versions of the "IDA" - $2100-$2300 per pair. They also have ported manifolds, linkage, parts, etc. They don't have a website as far as I know. Here's the contact info:
FAX: 310-394-6313 135 17th St. Santa Monica, CA 90402 The tennis balls? Used just like you said, but in race cars without air filters over the velocity stacks. -- Curt |
