bscotti's Avatar
Some Sort of Switch?
OK, I'm nearly ready for the spring driving season and have one last item to take care of ... my '73 originally came with A/C (long gone) and still has the blower, interior vents at the bottom of the dash, etc. I still use the blower as a fan, or should I say used to. I kept blowing fuses last fall and finally disconnected the switch (located in the front under the trap door with the old a/c equipment. Found one connector has corroded off!). My question is ... where do i get a new switch (Pelican perhaps?) and what do I call it when I ask for a new one? perhaps a Porsche part number?
Brian Scotti
'89 944 Turbo
'85 Skater 24
Old 04-03-2002, 05:38 AM
bscotti's Avatar
More info
OK, guys ... I've done more research and have found the following ... in the Porsche factory manual ('69-'72 ) in the TRA section, pg TR27, an option called The Recirculating Air Blower, p/n 902.571.910.00. This kit includes the switch I'm looking for, but doesn't mention it's part number. Any ideas??
Brian Scotti
'89 944 Turbo
'85 Skater 24
Old 04-04-2002, 08:40 AM
jriera's Avatar
Send a message via AIM to jriera Send a message via Yahoo to jriera
Brian, the blower swith for AC is 901.613.117.00 the temp.switch is 901.163.119.00.
Hope this helps..
Jordi Riera
'84 930 (modified)
Old 04-04-2002, 09:37 AM
jriera's Avatar
Ops.. wrong number.. the good ones are:
Temp. Switch: 901.613.119.00
Blower Switch: 901.613.117.00
Sorry.
Jordi Riera
'84 930 (modified)
Old 04-04-2002, 09:48 AM
bscotti's Avatar
Jordi,
Thanks for the part numbers. Just curious, where's you find them?
Brian Scotti
'89 944 Turbo
'85 Skater 24
Old 04-04-2002, 04:54 PM
Senior Member
Hello
Calll it blowerswitch 901 613 117 00
Check your blower motor sometimes a bit oil helps.
Grüsse
Old 04-04-2002, 11:55 PM
