Some Sort of Switch?
OK, I'm nearly ready for the spring driving season and have one last item to take care of ... my '73 originally came with A/C (long gone) and still has the blower, interior vents at the bottom of the dash, etc. I still use the blower as a fan, or should I say used to. I kept blowing fuses last fall and finally disconnected the switch (located in the front under the trap door with the old a/c equipment. Found one connector has corroded off!). My question is ... where do i get a new switch (Pelican perhaps?) and what do I call it when I ask for a new one? perhaps a Porsche part number?
Brian Scotti '89 944 Turbo '85 Skater 24 |
More info
OK, guys ... I've done more research and have found the following ... in the Porsche factory manual ('69-'72 ) in the TRA section, pg TR27, an option called The Recirculating Air Blower, p/n 902.571.910.00. This kit includes the switch I'm looking for, but doesn't mention it's part number. Any ideas??
Brian, the blower swith for AC is 901.613.117.00 the temp.switch is 901.163.119.00.
Hope this helps..
Jordi Riera '84 930 (modified) |
Ops.. wrong number.. the good ones are:
Temp. Switch: 901.613.119.00 Blower Switch: 901.613.117.00 Sorry.
Jordi,
Thanks for the part numbers. Just curious, where's you find them?
Senior Member
Hello
Calll it blowerswitch 901 613 117 00 Check your blower motor sometimes a bit oil helps. Grüsse |
