ncseahawk's Avatar
spindle o ring question
Ok...so I am replacing wheel bearings (front) and I have the 0 rings associated with the front spindles . question is if I didn't have any O rings on there when I removed the front hubs....
where do the new O rings go ? Do I need them at all .?
1985 Carrera Under Modification (SOLD)
2003 Carrera 4S
Old 12-28-2011, 10:53 AM
Are you calling seals "O" rings?
Old 12-28-2011, 11:22 AM
ncseahawk's Avatar
I am however this is what the wizard showed when I purchased the wheel bearings from our host
2003 Carrera 4S
Old 12-28-2011, 12:26 PM
m1franck's Avatar
The O ring goes behind the inner wheel seal collar and the base of the spindle. If you are not removing that collar, then don't worry about using the O rings
Old 12-28-2011, 02:25 PM
ncseahawk's Avatar
Got it. Thanks for the good news
2003 Carrera 4S
Old 12-28-2011, 03:21 PM
