!@#$% Missed a harness during engine drop- is this available???
The perils of a one man drop and inexperience- I was not aware of an engine harness connector on the body, and now one half of it is shot. 86 Turbo
Does anyone know what this is called, what it does, and whether it is available from PP or elsewhere? Thanks
Ken 1986 930 2016 R1200RS |
MBruns for President
yes- from our host
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Engine wiring harness plug
If you can´t find them anywhere else, these 14-pin connectors are available here:
Thomas __________________ 1973 911S Targa 2.4 |
76 911S Targa
It's this one I think:
Pelican Parts - Product Information: 911-612-113-05-M100
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Ed 1973.5 T |
$50 screw up...not too bad.
Don't feel bad though...I don't think it's fully your fault. Every write up I've seen for dropping the engine forgets to mention this connector in the front. I got lucky and happened to see it as I was dropping the engine, otherwise I probably would have been in the same boat as you.
Matt. 83 911SC 85.5 944 NA - Sold |
I you were going to break something, at least you broke something that can be replaced...and for not a lot of money.
I would still consider your drop a success.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
I can provide a replacement 14 pin connector
PM me for details |
83 911 Production Cab #10
+1, you won't regret it.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
