We may be confusing a couple of things here. The terms "two-stroke" and "four-stroke" specifically describe operation of reciprocating piston engines. We may need to speak in terms of thermodynamic cycles.
Four-stroke piston engines and Wankel rotary engines both utilize the same thermodynamic cycle (the "Otto cycle"). I've been looking through my thermo books but can't locate a definitive thermodynamic cycle for two-stroke piston engines...
Old 12-28-2011, 09:45 PM
Racer
winders's Avatar
Quicksilver,
Look here:
Wankel rotary engine Page 2
Scott
Old 12-28-2011, 10:02 PM
Honey Badger
theFONZ's Avatar
How is there argument an the number of "strokes?" The rotary HAS NO STROKES!!! It's not a 2 or 4-stroke, it's a rotary.
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 12-28-2011, 10:19 PM
Racer
winders's Avatar
Two-cycle engines have the "intake-compression" cycle and the "power-exhaust" cycle.
Scott
Old 12-28-2011, 10:36 PM
Racer
winders's Avatar
It's just semantics. We really mean "two-cycle" or "four-cycle". When applied to piston engines, we also happen to get the same number of strokes as cycles.
Scott
Old 12-28-2011, 10:38 PM
Honey Badger
theFONZ's Avatar
So a rotor has one cycle, an "intake-compression-power-exhaust" cycle. It's a fluid motion.
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 12-28-2011, 10:44 PM
Evan Fullerton's Avatar
2-stroke.... 4-stroke call it what you will but I will add this little tidbit to the 2-stoke list.
Some RX-7 guys disable the oil injection systems and premix their fuel. The factory system injects engine case oil to lube the Apex seals and due to the potential failures of these systems as well as the carbon buildup from burning engine oil, premixing 2 stroke oil in roughly a 100-1 ratio with the gas would seem to give better reliability due to less carbon buildup.
Old 12-28-2011, 11:37 PM
Racer
winders's Avatar
There are four distinct cycles that take place in a RX-7 engine.
Premixing oil with the fuel means nothing in this case.
Scott
Old 12-28-2011, 11:53 PM
Bothari's Avatar
Guys, as previously stated, 2-stroke and 4-stroke only apply to piston engines, and define the number of times a piston has to move (up or down) for a full combustion cycle.
If you want to compare this in similar terms to a rotary, you should really be speaking of 1 vs 2 cycle (or movement) engines: 2 strokes are 1 cycle, since they use the same cycle for compression/combustion and scavenging/intake. 4 strokes are two cycle engines since they separate the steps for compression/combustion and scavenging/intake.
By this logic, wankel engines are 2 cycle engines, since they also have separate "actions" for compression/combustion and scavenging/intake. Just don't call them 4 or 2 stroke.
Oil mixing in fuel: that has nothing to do with 2 vs 4 stroke, it's a question of mechanical logistics. There are 2 stroke engines with wet crankcases which have no need for oil mixing (the old ford orbital prototypes) and 4 stroke engines which need oil mixing (some old designs, usually).
Old 12-29-2011, 12:16 AM
Racer
winders's Avatar
Okay, if you want to get really technical, a typical four stroke engine has a single cycle called the "Otto cycle". The RX-7 engine has a single cycle called the "Wankel cycle".
Both "cycles" have distinct intake, compression, ignition, and exhaust components that make up the cycle.
Two-stroke piston engines have two components in their "two-stroke cycle". They are "intake-compression" and "power-exhaust".
Although completely different in design, the Wankel rotary engine has the same cycle components as an Otto cycle engine and much different than that of the the two-stroke cycle engine.
Scott
Old 12-29-2011, 12:39 AM
300hp 1800lbs is the goal
pksystems's Avatar
Fascinating. I'm still wondering what this has to do with 911 Technical tho
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 12-29-2011, 03:03 AM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
did you get it started yet?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 12-29-2011, 03:16 AM
wwest's Avatar
Originally Posted by winders View Post
Quicksilver,
No, you are incorrect. The RX-7 Wankel is a four cycle engine. No doubt about it. Just because it does all four cycles in one revolution does not make it a two cycle engine.
Scott
"..it does all four cycles in one revolutuion..."
Isn't that the very definition of a 2 stroke/cycle engine...???
Old 12-29-2011, 03:54 AM
wwest's Avatar
Scott
What....WHAT...??!!
The Wankel is a three "piston" engine with three firings in the (common) combustion chamber for each revolution of the "crank". An equivalent 4-stroke Otto engine needs to 720 degrees of rotation for that. If you understood the internals of the 2-stroke engine in my weedeater you would undoubtedly agree. Pick one of the Wankel's three "pistons" and follow it through 360 degrees of rotation.
All one really need do is look at the physical size, weight, of a 300HP Wankel vs an 300HP Otto engine to see just how radical the differences are. Check out Dempsey's Mazda at the upcoming 24 Hours of Daytona
Old 12-29-2011, 04:04 AM
Banned
Originally Posted by wwest View Post
What....WHAT...??!!
The Wankel is a three cylinder engine with three firings in the (common) combustion chamber for each revolution of the "crank". If you understood the internals of the 2-stroke engine in my weedeater you would undoubtedly agree. Pick one of the three "pistons" and follow it through 360 degrees of rotation.
lobe =/= piston
piston = piston
lobe = lobe
Old 12-29-2011, 04:12 AM
Bothari's Avatar
Scott
... What he said
Originally Posted by cockerpunk View Post
lobe =/= piston
piston = piston
lobe = lobe
Bingo! A wankel is quite different to a piston engine. Might as well also compare a gas turbine to a piston engine and call it a 0-stroke engine
Old 12-29-2011, 06:24 AM
lupin..the..3rd's Avatar
Send a message via AIM to lupin..the..3rd
Originally Posted by rattlsnak View Post
I dont know much about rotary engines. What turns them? etc.. lol..
Wankles are the devil's work. They're powered by triangles and witchcraft. Run away!
SOLD: '87 Carrera
Old 12-29-2011, 06:37 AM
Racer
winders's Avatar
What....WHAT...??!!
What do you mean by "What..??!!"? Read post #30 again. It is technically accurate.
The Wankel is not:
...a three cylinder engine with three firings in the (common) combustion chamber for each revolution of the "crank".
What you call the crankshaft, the "output shaft" or "eccentric shaft", rotates three times for each rotation of the rotor. There is one firing for each rotation of that shaft.
Scott
Old 12-29-2011, 07:26 AM
Information Junky
island911's Avatar
especially since they really don't have a 'stroke' at all.
Spot on. The number of Crank rotations do not apply. (lots of cranky posts here)
It's a 4-wobble engine.
fwiw, the Wankel has positive displacement cycles - 4 of them- where as a 2-stroke has two. ...relying largely on air flow properties (harmonics) for scavenging.
Old 12-29-2011, 08:23 AM
Information Junky
island911's Avatar
Well, actually, those triangles (wedgie combustion chambers) do actually suck for capturing the bang. (so to speak)
That is why they are an inherently flawed design/configuration. ..so yeah, Run away!
Old 12-29-2011, 08:28 AM
