What's your engine "cold start" routine?
Anyone that's been around these cars knows they have individual quirks...a personality. That may be one of the things that's endearing about a 911. I thought it would be interesting to find out what your "cold start" routine is, and see if there was some consistency in like cars or if all are different. Please include the year of your car and if it is stock or modified. I thought it was funny that the PO's of both of my 911's gave specific startup instructions.
I'll kick it off with my experiences. 1970 911 E 2.2 with Webers - pump the pedal three times foot off pedal engage starter feather in gas as engine catches 1979 911 SC stock - Stay off pedal during process engage starter engine starts, runs 5 seconds and dies engage starter engine starts, coughs a couple times fast idles up to 2K rpm settles back in to smooth idle at 1K
LGBFJB |
Crotchety Old Bastard
Your SC should not do that.
My '78: Tranny out of gear Hit key Motor starts and runs at 1500-1800rpm for a few minutes, then settles down. Sometimes throttle may need to be applied lightly until rpm rises to 1500-1800 due to warm weather conditions. '73T w/Webers & Headers: Tranny out of gear Pump throttle lightly as quickly as possible while turning over starter. Keep doing this after car starts until idle is maintained by lever between seats. The sound of that motor was soooooooooooo cool! Like an Indy car. It would rev quicker than you could pump the gas.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 Last edited by RarlyL8; 04-04-2002 at 07:24 AM.. |
Senior Member
For the SC, do either of you turn the key to pressurize the fuel and wait, then turn the key to start?
John
'78 Targa in Minerva Blue |
I agree, your CIS car shouldn't start like that.
My 79 SC at -15 F Engage starter. It will fire up after a second or two, idlez smoothly at about 1800 rpm. watch oil pressure come up, put on seatbelt, drive conservatively till the temps come up. You've got a problem with your SC that you've just been living with. I hope you have a pop-off valve in your airbox!
Bill Krause We don't wonder where we're going or remember where we've been. |
Senior Member
My SC has had the little fuel cutoff switch unplugged because it is not working,. so when I turn the key on, the fuel pump starts running.
I usually turn the key and wait for about 2 seconds before cranking it. When the car is cold, it acts almost identical to yours Expat. stumbles and dies... turn it off, try again... fires up reves, then drops and stumbles... then catches itself and revs again up to about 2500 rpm and stays there for a few minutes... then in steps... it drops back down to normal idle. I know it's not right, but I've been living with it. ![]() Maybe someday I'll sort it out.
-- Chief Architect and Mastermind, SCWDP |
Guest
Posts: n/a
Jdub
I do that, but I don't think it's necessary My DME 3.2 idles at app. 1200 rpm when cold and quickly settles to app. 1000 rpm. When warm it's just under 900 rpm. |
My car had similar cold-starting issues until I adjusted the timing. Now, no matter how cold it gets, it fires right up, idles about 1800 for a couple of minutes and then settles down to 900 RPM.
Mark my 76S does almost the same starts then almost dies then goes to about 2000 then settels down to 900
65 911/ 301274 sold 66 911 /303509 sold 67 911/ 355032 68 911 softie sold 70 T with s trim |
Hit the key starts, 1800-2000 rpm for a couple minutes and then down to about 900.
Robert Stoll 83 911 SC 83 944 |
Senior Member
Mikkel:
My car is pretty well-behaved, but it is headed in the direction of Lee's I am sure. Over time (and this is a daily driver so it gets started cold every morning) I am finding that I am getting the "dip" when starting. So the process is start, jumps to 1600rpm, dips low, struggles for a second or two, then idles up around 1600rpm for ~2 minutes, then back to 1000rpm (cold now, around 30degrees). I think it is only a matter of time before it gets to the heart-stopping state where it must be restarted. So I have tried turning the key, waiting a bit, then turning the key to Start mode. Seemed to work just fine this AM, but mixed results. If we can figure this out we will have helped a lot of folks I am sure. John
Anyone with early MFI cars chime in?
I'll start. 1. Depress clutch pedal. 2. Engage hand throttle to top. 3. Crank for about 10 seconds until it is turning over fast enough to catch. 4. Usually idles at 1200-2000 working out its bugs for about 10 seconds, and then pops up to 2500-3000 once it smooths out. 5. Reduce hand throttle to 1200 until it warms up.
1994 RS America http://www.pelicanparts.com/gallery/9XI 1964 13-Window Deluxe Walkthrough 1999 Eurovan Camper 1969 911S Targa -- gone but not forgotten |
Blockchain Tech Inventor
'86 3.2L Carrera
1) Tranny out of gear, clutch out 2) Crank the key - starts immediately 3) Idles at 1000 for about 2 seconds, surges to about 1300 for about 2 seconds then settles around 900+ 4) Take off, stay under 4400 RPMs for at least 5 - 10 minutes 5) Try to avoid hitting the rev limiter the rest of the drive JrDavid68 |
stock '77 2.7 CIS
-netural -clutch out, don't want to load eng. thrust bearing without oil psi. -routine start -eyeball CHT first, then oil temp...adjust driving to ga. readings
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
On an SC, if your fuel pump comes on when you turn the ignition to ON, then your airflow detect switch is disconnected. Besides bypassing a safety feature of the car, you are also applying power to both the WUR and the aux air regulator before you are starting the car. If you wait too long, then you may be missing the enrichened cold start mixture that the WUR provides. I also think that the extra couple of seconds that the engine cranks before firing helps to get the oil flowing.
It is kind of cool to have the engine fire up that fast though.
before step 3. (above) turn ignition on. Wait 5 seconds for electric fuel pump fill up system.. then on to step 3. (cranking) This should prevent a lot of cranking.. It always worked for me, my baby would start within 2-seconds. Now I have webbers : - ( my MPG has been cut by a third, and I am back to the old pump - 1/4 throttle - turn key routine.. And drive it as soon as you can, slowly, this will warm you up the fastest. |
Senior Member
Very good point Mr. Krauss.
My old mechanic (before I hired myself) unplugged it because it was malfunctioning. When I rebuilt my motor, I plugged it back in and tried to start it. No go... so I unplugged it and just reverted back to the old way of having the pump running in the on position. I know it is also a safety device... Any ideas of how to fix the switch???
Now I'm curious. Where is this airflow detect switch and what does it look like? Pics would be helpful. It sounds like mine may be disconnected as well.
Mark
LGBFJB |
78 SC :
Get in Turn key ...foot not on gas pedal Motor starts immediately. Idles @1800 RPM for a minute or two depending on outside air temperature Then settles down to 900-1000 rpm idle wckrause: My SC's fuel pump does indeed run when I turn the ignition key although the PO's said nothing about disconnecting the airflow detect switch. What would be the benefit of doing so? |
72 mfi. Put in neutral, pull hand throttle up 2 inches, turn key to on position, listen to fuel pump and all those bubles being pushed out, start car which takes about 2 seconds of cranking. Leave hand throttle at about a half inch until car is warm.
72 911 Although it is done at the moment, it will never be finished. |
wow...very elaborate rituals
i just turn my key and back out of my parking spot...baby it till the temp needle is out of the thick white block at the bottom then off we go!!! |
