It took only 49 years!
Ssi compatibility question
Can a thick-flanged SSI that was originally on a 3.0 engine fit a 3.2?
Serge: In the heart of Philly! Daisy - 1972 911T 2.7L Light Yellow Veronica - 1987 911 Carrera Coupe Indischrot, M&K GT3 muffler and Euro Pre-Muffler, SW Chip SOLD ![]() Lil Blue - 2002 Subaru WRX Wagon (my dd/HPDE car) SOLD
The bolt spacing is the same. The thick flange were originally meant for the longer 3.2 studs, which you should have.
Were the inserts cut off the SSI's? If so then they will still fit but you will have to use the 3.0 gaskets, which are cheaper, but you lose the blow-out protection form the insert and the metal 3.2 gasket. Without the insert the step down form the 3.2 exhaust port may create a little turbulance in air flow, I dont think you will notice.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Normally yes.
You'll just need washers ( or a custom piece of metal) to compensate the flange height.
LIGHTER = FASTER !!! |
The 3.0 exhaust ports are smaller thqn the 3.2 though. Is it advisible to use them?
Matt. 83 911SC 85.5 944 NA - Sold |
For each system, at the point where the exhaust meets the ports are both 38mm which matches the ID of the SSI's. When using SSI's with the sleeves (inserts) removed, a step would remain open which could cause a little turbulence
Shane, I have to respectfully disagree with you there. I think you are mixing up the two different types of SC engines.
The 78-79 has thin flanges and no colars. The 80-83 has thick flanges with collars, but the diameter of both.are the same. The 3.2 has thick flanges and larger collars due to the larger diameter exhaust ports. A 3.2 SSI does not fit on a late SC engine unless you cut off the collars.
But will the opposite work: A 3.0 SSI on a 3.2 engine?
Technically it will fit. But i would be worried about choking down the exhaust at the flange.
Why do you want to use Ssi's on a 3.2?
I used the thin flange SSI's from my 1973 on my 3.2 conversion and it ran great. If I was going to track the car I might consider something else, but on the street it pulled very well with a bursch muffler.
1973 Porsche 911T 3.2 Engine.wmv - YouTube
Ed 1973.5 T |
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Recreational User
The 3.2 needs 1.625" primaries, but SSIs are 1.5", which is really too small. This was discussed at length in this thread -
Best exhaust with heat for a 3.2? |
I agree with everything you have said here. I think I read into the OP question.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 01-06-2012 at 04:43 PM.. |
