1985RedTarga's Avatar
Bought some stone guards, can you help?
I bought some stone guards for my 85 Targa, no turbo here, from our host. Does anyone have details on where to accurately apply them? Any help would be great so that I don't screw it up.
Jamie
Jamie
1985 911 Targa
Old 01-17-2012, 07:23 PM
vash's Avatar
you install them pretty much like window tint. i used a lean soapy mix. i scooted it around until i felt it looked right, and then squeegied out the moisture to stick it in place.
poof! gone
Old 01-17-2012, 09:27 PM
I used a small piece of masking tape to mark how high my rockers sat on the side of the car so that the bottom of the stone guard went below this level. I then lined up the curved line of the wheel well with the curvature of the stone guard and marked at the top with another piece of tape where the top of the guard was going to rest. As the previous poster stated soapy water sprayed on the back of the guard and the side of the car will allow you to move the guard around to the right spot on the car. Then squeegy out the water. Also look at some pictures of other cars to see where they line up.
"Charlie don't surf!"
Old 01-17-2012, 10:11 PM
Thank you both!!
Jamie
1985 911 Targa
Old 01-18-2012, 05:20 AM
mystro's Avatar
I measured the height on both sides and used masking tape to mark the top of the spot where the decal starts. On my latest 911, I bought a set of magnetic stone guards. I plan on doing a review when it gets warmer out.
Old 01-18-2012, 05:28 AM
Send a message via Yahoo to chris.817
They should just tuck under the rubber part of rocker panel and follow the curve of fender flair as best as possibly. It will likely not fit perfectly.
Chris
87 Carrera Coupe - Guards Red on black
00 Carrera Cab - White on Navy
05 Carrera S - Atlas Grey on gray
86 951 - India Red on black - Sold
Old 01-18-2012, 08:42 AM
Got the stone guards from our host a few days ago. So I'm looking at the area where they go and notice the "cap" where the torsion goes.
Am I crazy, but is that gonna hinder my effort?
Jamie
1985 911 Targa
Old 01-24-2012, 09:33 AM
They go over the torsion bar cap.
Old 01-24-2012, 07:50 PM
Taking it apart is easy
Jerome74911S's Avatar
There is good advice above and I second all of it. The odd thing is that the bottom of the guard does not line up with the rubber moulding on the car, and you have to stick a triangular portion of the guard under the rubber. In other words, the "factory" stone guard is made in a shape that won't fit the car without jockeying it around a fair amount.
Don't be afraid to use something that won't make scratches to pry out the rubber moulding so you can work. The stone guards fit differently on each side of my car, but I can't see both sides at once, so who cares.
I like them.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 01-25-2012, 07:47 AM
I just did these but needed to step up to the Turbo guards as the smaller ones didn't overlay well with what was there from the factory for 30 years. The faded lines and such just couldn't be covered to my liking so the larger ones covered all the uglies. As stated, the base of the guards just don't line up with the rockers when the curve is followed. I just trimmed mine with an razor after installation, worked just fine.
Thanks,
Chris
1980 Targa, 3.2 upgrade
Old 01-25-2012, 11:08 AM
So the black half circles that are above the black trim should just pop off and I place the sticker over the cap? I'm assuming that they are just rubber?
Jamie
1985 911 Targa
Old 01-25-2012, 11:29 AM
Shhhh... Uhhh
Creve's Avatar
Interesting idea. Where did you get the magnetic ones?
"Dyin' ain't much of a livin' boy."
- Outlaw Josey Wales
Old 01-25-2012, 12:46 PM
grando's Avatar
I've had a set of magnetic ones on my 83 SC and they work great. Got them from rennline
Grand
Grand F. Wong
83 911sc Cabriolet
1987 911 Carrera WB
Old 01-26-2012, 04:11 PM
Ok, how do I deal with these rubber gaskets for the torsion tube? Do they pop out? Or should I just put the stone guards right above the gasket???
Jamie
1985 911 Targa
Old 01-30-2012, 10:49 AM
gtc gtc is offline
abides.
gtc's Avatar
Remove the rocker endcaps.
Slide the rubber rocker trim towards the front of the car.
Clean area well (duh)
Make the torsion bar cover and seal to fit as flush as possible with the fender.
Apply stoneguard over torsion bar cover and seal. Lower edge should be hidden by the rubber trim, rear edge should be as close as possible to the front edge of the fender lip.
Slide rubber trim back and reattach endcaps.
Graham
1984 Carrera Targa
Old 01-30-2012, 11:17 AM
gtc gtc is offline
abides.
gtc's Avatar
Here's an old shot of my car:
Graham
1984 Carrera Targa
Old 01-30-2012, 11:22 AM
mystro's Avatar
I bought mine from Dan at MagnaGrafik Home - Porsche Graphics, Magnetic Decals for Porsche, Magnetic Hood Stripes, Magnetic Stone Guards, Carbon Fiber Graphics, Vinyl Graphics, Porsche 911 Carrera Boxster Cayman Turbo Decals, Martini Racing Stripes, 911 914 930 935 944 964 96
Made in Ohio. Great guy. I recommend the product and the company highly. In my mind, having owned cars with the traditional stone guards, the magnetic ones are the only way to go. They look great and can be removed or installed in seconds. No more waxing around decals.
Old 01-30-2012, 11:54 AM
Pretty car.
Jamie
1985 911 Targa
Old 01-30-2012, 06:38 PM
Registered Loser
Is yours the matte black or gloss black? $50 pair, not too bad. Car is stunning!
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320
Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180
Old 01-30-2012, 07:41 PM
So what happens if you need to access the torsion bar cover and the vinyl stone guard is on there?
Sent from my SM-N920V using Tapatalk
1979 911SC Euro Tub/1982 Euro 3 Liter PCA E Class Race Car
1985 911 Carrera Coupe-Grand Prix White/Red
Old 05-15-2016, 09:12 PM
