Questions RE: Power Window Harness Routing
Greetings,
I'm installing power windows into my '74 non-power window car. The harness is similar to all the other harnesses and has 2 plugs that go thru the front trunk to under the dash. I've found (what I think is) one rubber cap on the driver side, just near a vent hose, where I believe one of the pass-thru plugs goes. However, I cannot find anything on the passenger side. See Pictures Below: Can anyone provide a trunk photo that shows where the power window harness passes thru the trunk to the cabin. I hope I don't have to drill a hole and someone can tell me where an existing hole is. If I must drill, I'd like to get it where it's supposed to be. Rubber Cap on Driver Side - I believe the harness passes thru here on driver side: ![]() Harness - 1 of 2 plugs that pass thru the trunk to cabin ![]() Any help would be greatly appreciated...................Vern |
I should know better to not post questions on Friday night.
Anyone? |
