Administrator
Jack Olsen's Avatar
4.0- and 4.2 liter upgrade kits
I stumbled across this outfit's web site, and now I can't find it in my bookmarks. It's an company that does 4.0-liter and 4.2 liter upgrades from a 964 or 993 base. Does anyone know their name?
Old 04-11-2002, 08:06 PM
Hilbilly Deluxe
emcon5's Avatar
Is this them?
http://www.cmwracing.com/
Tom
82 911SC Coupe
GTI Cup #43
Old 04-11-2002, 08:09 PM
Send a message via AIM to 82SC
is it just me or does the interworkings of JO's mind frightening...
Old 04-11-2002, 08:18 PM
cary's Avatar
I think Jack's in the quest for clean air.......
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 04-11-2002, 09:03 PM
Administrator
Jack Olsen's Avatar
That's it. Thanks.
Just window shopping, at this point.
Old 04-11-2002, 09:17 PM
Wow! I had no idea whoopin' yo' ass on the track would upset you that much ...
I think I remember an ad in Pano for Kolbenschmidt pistons of similar displacement...
(everyone wants to be like Jack, but Jack wants to be like me
Old 04-11-2002, 10:00 PM
turbo dave's Avatar
Wow, 4.2! In a 901 motor! That seems like a lot, does it really work?
Come on, Jack, why not just build up a flat 8? Just a custom sandcasting & crank, plus about a hundred other little details. You could track down a 908 for inspiration, I'm sure there's one around down there!
David Schultz
1973 911T 2.7
Old 04-12-2002, 12:19 AM
beepbeep's Avatar
Hmm...you guys ever heard about turbo?
Turbo + 3.6L = horsepower at will ... you could skip the intercooler if you want to keep that rear lid nice & clean...but it should deliver plenty of HP @ moderate boost still....and cost about the same.
Add then intercooler, crank the boost to 1.0 bar and you're off...
Thank you for your time,
Old 04-12-2002, 02:08 AM
Beepbeep,
Even at 0.5 bar, the compression ratio would still be too high. What's your CR, Jack? It's something like 10.3 or 10.8:1, right?
Also, adding a turbo would add more weight, and from what I understand, Jack doesn't want anymore weight back there.
I kinda like the idea of a flat 8!
Matt Holcomb
1974 911 Carrera 2.7 RoW
1975 Mercedes-Benz 280SE
Dedicated Homepage
Engine Rebuild Homepage
Porsche Owners Gallery Profile
Pelican Gallery Profile
Old 04-12-2002, 04:03 AM
juan ruiz's Avatar
Jack, Is all clear 4.2 Twin Turbo I know some day just some day you may joint the turbo ranks!
Regards
Juan
3.2 Undercover
Old 04-12-2002, 04:45 AM
Metal Guru
911nut's Avatar
Jack's working his way up to one of those JATO rockets strapped to the back of his beast.....
Old 04-12-2002, 05:39 AM
beepbeep's Avatar
Of course, turbo-conversion would mean that you need to lower CR to 1:8.0 or something...
Fun part is that you get heaps of power simply. If you are not a hooligan, install smaller and easier-spinning turbos and keep power output and boost under 400HP you can get really plesent and tractable engine that will pull away from everything.
I mean, what's the point with 300HP N/A horses if they arrive peaky at sky-high RPM...it's faster to have meaty & flat torque-curve in entire rev-range, even if top HP is the same!
Keeping it down with small turbos and moderate boost will help kill turbo-lag as well and will make potent engine, without mucho $$ and exotic stroke-adventures connected with hi-po tuning of N/A engines.
Yes i know you guys like bark of N/A engines and think that turbo's are lazy...but at this point where Jackie O is, i think that's a good idea as long as he's focused at faster lap-times more than "feeling of the car".
I have a friend that did dual-turbo conversion of 3.6L with low C/R pistons and he can extract anything from 300 to 600HP depending on driveability, life-span and engine character...
Of course...that would also mean that Jack would stray from "we-nice-guys-with-lovely-SC's-and-N/A-engines" to our beloved "HP-junkie-pour-it-on-baby" camp....but that's another story. :-)
Old 04-12-2002, 06:54 AM
RLJ RLJ is offline
Senior Registered User
Gettin' Thin
The racers say that that 3.8 motors are fragile on the top end keeping things sealed. 4.0 4.2 would be harder to maintain. Maybe runnin' at sub full bore race they might last longer, just a guess.
Randy Jones
1971 911
Old 04-12-2002, 08:47 AM
Ifn itwere mine, I would stick with 3.8, Ruf Ti con rods, either FVD MAF or go to Motec, 3.8 RS cams, fully flowed heads, ARP hardware, and be resigned to suffer along with only 350 hp a barely streetable engine, And a very light wallet.
Old 04-12-2002, 09:20 AM
juan ruiz's Avatar
Beep Beep AMEN......
Old 04-12-2002, 09:56 AM
Crotchety Old Bastard
RarlyL8's Avatar
I think the N/A crowd is better suited to supercharging for additional power. The dreaded L-word scares them off.
For similar dollars as a 3.8-4.2L upgrade you could bolt on a low output SC w/intercooler. If you want more you can lower the compression later on (pistons only) and turn up the wick. Gobbs of torque to be had.
Old 04-12-2002, 10:31 AM
beepbeep's Avatar
I don't think people understand that acceleration is a function of torque troughout rev range and that peak power figure is just a measure of power curve "peak"...
Old 04-12-2002, 11:35 AM
Exactly. A friend of mine just bought a crotch rocket (aka sport bike) which has about 120HP. This is over 2x the HP of the VW single cab pickup that he owns, which has ~55HP. Yet, you would not want to put the motorcycle engine into the pickup, and fill said truck up with sand and try to drive it. You can do that with the 54HP engine, but you wouldn't get out of the driveway (much less materials yard) with the motorcylce engine.
It's all about the torque, baby!
Old 04-12-2002, 11:52 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Originally posted by JackOlsen
That's it. Thanks.
Planning on torture testing your latest 915 Jack?
Hope the latest 915 is more stout than the previous box!
Kevin L
'86 Carrera "Larry"
Old 04-12-2002, 12:16 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Remember guys.....
A little is good
More is better
And too much is just about right!!
And...the only way to beat cubic inches is with rectangular dollars.
Bob
Bob Hutson
Old 04-12-2002, 01:10 PM
