The original stock '77 CIS dizzy was border line w/.007 shaft horiz. play. The future is E-cams and PMO so I gave a 2.7 Carrera dizzy a shot w/stock '77 CIS...Works fine/great, no problem w/CIS..I did the no-vac.,10 deg initial to see what happens. I richened the CIS very slightly w/the cheap gas analyzer. I could probably tweak w/vac. adv and 0 initial, not sure what will happen....The dizzy comes w/points, cap, and rpm limit rotor....Pelican gets about $275...Bosch PN 0.231.184.004...
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
