Zenith rebuild help
Hi Guys hoping for a little help, I am in the middle of an attempt at rebuilding
the zenith's on my 73T 2.4
I am following a post from "A Quiet Boom" and I thank him very much as I would
not attempt without the guidance like this from this forum.
Anyway doing the drivers side first and I removed the squirters and when I turned
it upside down to shake out the check valves the one in the middle is brass and
looks like a screw with no thread like it should but the two out side ones were
two approx 5 mm s/s ball bearings.
So either the bearings fell out of another hole or someone subbed these in place of
the original check valves??
Any thoughts or advise?
Thanks in advance
Mike
Old 02-11-2012, 02:44 PM
anybody??
Old 02-11-2012, 04:24 PM
1QuickS's Avatar
The little "brass screw w/o the slot" that fell out is a check valve and the ball bearings are probably an adequate alternate.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 02-11-2012, 05:16 PM
Thanks 1QuikS that's what I figured other than the popping the engine
seems to run ok.
Does anyone know if the brass screw like check valves are still available?
Mike
Old 02-12-2012, 06:00 AM
Also Paul you made note of the "screw with out a slot" and the one that
fell out has know threads but it has a slot on both top and bottom and
the direction of the slot is opposite each other.
Mike
Old 02-12-2012, 06:09 AM
1QuickS's Avatar
Direction of the slot not important, the piece just drops into the bottom of the well; my mistake regarding the slots.
There is a seller on eBay that sells Zenith parts; he is "alfa1750" and is in Italy. I buy from him as do many others.
Paul Abbott
Old 02-12-2012, 03:22 PM
LakeCleElum's Avatar
I might have another check valve.....I have one spare Zenith for parts. Just mailed the same part to a Pelican member in Portland last month.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 02-12-2012, 03:47 PM
thanks Bob but looks like I'm missing two in this carb and I haven't taken the
passenger side carb apart yet as i'm using it as my pattern for when I put the
first one hopefully back together.
Guess I better at least take the top half off and see how many I will need.
Thanks very much for the help guys
Mike
Old 02-12-2012, 06:17 PM
9112.2t's Avatar
Zenith setup Manual
here is a link that helped me along the way, Zenith 40 TIN Carburettor Manual
1975 Targa W/ 2.2
1971 Sunroof coupe 2.2T Gone but not forgotten
Old 02-12-2012, 06:23 PM
Yes thanks Bob I have been using that site as well and I think I have printed off half
of that site its good reference material for identifying the bits and pieces.
Mike
Old 02-12-2012, 06:39 PM
