Slim Hips Guy
Can I cram 15x7 rims under my unmolested 74?
Hello,
I have a 74 911 with original lack of flares in the rear that came originally with 15x6 rims. I have a line on 15x7 rims but I am not sure if the extra width will cause any issues or can I just run shorter tires or tighten up the torsion bars.
Thanks in advance.
John
Old 02-13-2012, 04:39 PM
Look at my pictures
I ran 15x7 fuchs with 205 /60 15 tires
and also 15x8 with 205 50 15
Check out my garage and you will see the 74 911.
I had no issues with tires. The front didnt even rub the wheelwell.
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 02-13-2012, 04:43 PM
Send a message via AIM to fintstone
This recent thread might help:
Tires for 15" wheels?
205/55R-15 Yokohama AVS ES100s is the best I could do after much measuring (different brands and styles of tires fit different even if the same size). The same tire on a 6 inch wheel that fits may well not with a 7 inch wheel. The problem is usually in the rear...especially if your suspension is worn out or set too low.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 02-13-2012, 05:48 PM
Shaun @ Tru6's Avatar
Yes, and if you find can them, 225/50/15s will fit with a lot of negative camber even with a 24 inch rear ride height.
Tru6 Restoration & Design
Old 02-13-2012, 06:00 PM
Slim Hips Guy
DohertyCM- That is exactly what I wanted to learn. Thank you very much.
fintstone- Thanks for the link. I suppose I have even more to think about. ;-)
Shaun 84 Targa - I love those Magnesium Cookies. I would prefer those over the aluminum painted version but I am told the Mag wheels have the potential to be brittle in the winter cold. Have you heard the same?
I think I have Michelin 205/55-15s on my Accord wagon. I can't imagine the same tire on my 911.
Thank you again.
Old 02-13-2012, 11:10 PM
All cookies are simple aluminum alloy, so you will be good at any temperature. I stripped and bead blasted these, 7x15s all around.
I don't know that magnesium is brittle in winter cold, that would pose a problem for both wheels and early mag cases alike.
Good luck!
Old 02-14-2012, 03:18 AM
IROC's Avatar
I ran a variety of wheel and tire combos on my '76 before SC flares. 205/60-15s fit easily on 7x15s all around and are pretty close to the typically stock 25" diameter that Porsche seems to use. In my case, 225/50s needed fender lip rolling and some negative camber, but also help out in the gearing department with their 23.85" diameter.
IMHO, 225/50-15s on 7x15s all around makes for a great looking and great handling combination.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-14-2012, 04:27 AM
kwikt 911's Avatar
225/45/15 Hankook C71 autocross tires on 7x15 cookies. Lowered with alot of negative camber. If for the street use I would opt for 205 series on 7x15 rims though.
72 911t
92 968
03 BMW330i
11 Ford F-150
01 HD Fatboy
Old 02-14-2012, 06:13 AM
Slim Hips Guy
Did you start with the commonplace rim that has a polished lip and black center star? I have access to a beadblaster but I have never taken on the task myself. Any tricks to getting that 'alloy' look?
John
Old 02-14-2012, 07:08 AM
tobluforu's Avatar
I run 15X7's on my car with 205/50's all the way around. I run 1\4 inch spacers in the front so I could probably run 215's-225's there, but 205's is about all the rears can take, I think?. I have not tried anything over 205's in the rear, but I really don't want to purchase tires only to find that they rub as my car is pretty low and I run pretty much full camber in the back. I will need new tires this summer, so should I bite the bullet and try something wider, maybe two tires first, install on rear and if they rub move to front and remove spacers?
Old 02-14-2012, 07:35 AM
I'm running 16x7's rear & 6's in the front with 205/55/16 all around. I wouldn't think you would have a problem.
Old 02-14-2012, 07:51 AM
