Slim Hips Guy
Can I cram 15x7 rims under my unmolested 74?
Hello,
I have a 74 911 with original lack of flares in the rear that came originally with 15x6 rims. I have a line on 15x7 rims but I am not sure if the extra width will cause any issues or can I just run shorter tires or tighten up the torsion bars. Thanks in advance. John |
Look at my pictures
I ran 15x7 fuchs with 205 /60 15 tires
and also 15x8 with 205 50 15 Check out my garage and you will see the 74 911. I had no issues with tires. The front didnt even rub the wheelwell.
Signature Phrase " CATCH ME IF YOU CAN" 1988 Porsche 930 "Squerly" Built by "Porsche Doc" -------------------------- 1974 Porsche 911 (2003 - 2012) 2000 Boxster S (2006 - 2008) |
This recent thread might help:
Tires for 15" wheels? 205/55R-15 Yokohama AVS ES100s is the best I could do after much measuring (different brands and styles of tires fit different even if the same size). The same tire on a 6 inch wheel that fits may well not with a 7 inch wheel. The problem is usually in the rear...especially if your suspension is worn out or set too low.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender Last edited by fintstone; 02-13-2012 at 05:53 PM.. |
Yes, and if you find can them, 225/50/15s will fit with a lot of negative camber even with a 24 inch rear ride height.
Tru6 Restoration & Design |
Slim Hips Guy
DohertyCM- That is exactly what I wanted to learn. Thank you very much.
fintstone- Thanks for the link. I suppose I have even more to think about. ;-) Shaun 84 Targa - I love those Magnesium Cookies. I would prefer those over the aluminum painted version but I am told the Mag wheels have the potential to be brittle in the winter cold. Have you heard the same? I think I have Michelin 205/55-15s on my Accord wagon. I can't imagine the same tire on my 911. Thank you again. |
All cookies are simple aluminum alloy, so you will be good at any temperature. I stripped and bead blasted these, 7x15s all around.
I don't know that magnesium is brittle in winter cold, that would pose a problem for both wheels and early mag cases alike. Good luck!
I ran a variety of wheel and tire combos on my '76 before SC flares. 205/60-15s fit easily on 7x15s all around and are pretty close to the typically stock 25" diameter that Porsche seems to use. In my case, 225/50s needed fender lip rolling and some negative camber, but also help out in the gearing department with their 23.85" diameter.
IMHO, 225/50-15s on 7x15s all around makes for a great looking and great handling combination.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
225/45/15 Hankook C71 autocross tires on 7x15 cookies. Lowered with alot of negative camber. If for the street use I would opt for 205 series on 7x15 rims though.
72 911t 92 968 03 BMW330i 11 Ford F-150 01 HD Fatboy |
Slim Hips Guy
Did you start with the commonplace rim that has a polished lip and black center star? I have access to a beadblaster but I have never taken on the task myself. Any tricks to getting that 'alloy' look?
John |
I run 15X7's on my car with 205/50's all the way around. I run 1\4 inch spacers in the front so I could probably run 215's-225's there, but 205's is about all the rears can take, I think?. I have not tried anything over 205's in the rear, but I really don't want to purchase tires only to find that they rub as my car is pretty low and I run pretty much full camber in the back. I will need new tires this summer, so should I bite the bullet and try something wider, maybe two tires first, install on rear and if they rub move to front and remove spacers?
72 911 Although it is done at the moment, it will never be finished. |
I'm running 16x7's rear & 6's in the front with 205/55/16 all around. I wouldn't think you would have a problem.
