Disbanded
juanbenae's Avatar
engine shroud treatment?
anybody have a line on a recondition of a 30+ yo fiberglass engine shroud? looking to dress it up a bit while the motor comes apart. figure powder coat would crack with the expanding n contraction of the thing. what have you done to dress this up.?? links to interesting threads you may know of on the topic are welcomed.
t
Old 11-10-2012, 06:06 PM
Is it possible to powder coat a fiberglass shroud? I thought powder coating worked using an electrical charge?
How about cleaning it and then poliching with some fiberglass polish? Maybe some rattle can paint.
Old 11-10-2012, 06:43 PM
donagain1's Avatar
Looks like someone may have painted it already... mine's black all the way through, and it prettied up icely with a couple of spritzes of ArmorAll.
Old 11-10-2012, 06:52 PM
hkspwrsche's Avatar
Glass should be prepped and painted at a paint shop no powder coat.
Harold
Old 11-10-2012, 06:53 PM
al lkosmal's Avatar
shroud
I wetsanded mine, then used rubbing compound and then shot it with a few coats of satin clear.
RGruppe #669
http://www.x-faktory.com/
Old 11-10-2012, 06:57 PM
That looks great Al. Was the satin clear out of a can?
Old 11-10-2012, 10:47 PM
ROW '78 911 Targa
timmy2's Avatar
Clean it and paint it with orange chevy engine hi temp enamel . Very, very close in color to original on my '78.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-10-2012, 11:04 PM
Senior Advisor
James Brown's Avatar
i believe they make them like a boat hull, colored gelcoat on first then fiberglass chop. If you are careful on the sanding you can get back to the original color, wax and polish or clear coat like Al says should do it. If there is damage or the fiberglass strands are coming through, time for paint.
08 Cayenne Turbo
Old 11-10-2012, 11:40 PM
ROW '78 911 Targa
timmy2's Avatar
+1 Mine had some damaged areas that I repaired before painting.
Dennis
Old 11-11-2012, 12:49 AM
kodioneill's Avatar
Rustoleum red enamel.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-11-2012, 07:57 AM
Disbanded
juanbenae's Avatar
thanks guys. thread saved for reference when i get to the task. out to the garage to clean up before tear down.
Old 11-11-2012, 08:49 AM
al lkosmal's Avatar
yes, it was rattle canned.
RGruppe #669
Old 11-11-2012, 08:52 AM
