-   -   Using wide band to tune cis? (http://forums.pelicanparts.com/porsche-911-technical-forum/660248-using-wide-band-tune-cis.html)
village idiot 02-22-2012 09:14 PM
Did a search but nothing conclusive. I just purchased this out of curiosities sake to see what my afr is at full throttle.
PLX Devices Inc - USA
http://www.plxdevices.com/images/plx...d_page_WIP.png
Gonna try to install it next weekend and see what we see:cool:
jrolstin 02-23-2012 12:35 AM
Cool, I was always interested in getting the innovate LM-2 wideband with logger... But didn't know how you would trace it vs. RPM. I wonder if you can log multiple channels with it? Oh well I will look into it more when I have the money...
WPOZZZ 02-23-2012 12:45 AM
Tom - I have a LC-1 with turbo timer in case you want to try one of those. All I know is I keep blowing out o2 sensors. lol
village idiot 02-23-2012 12:46 AM
I wanted to try it as I have a friend with a turbocharged, VW powered Manx buggy. He's running a blow-through carb set up and he swears by the PLX wide band to aid in tuning.
theFONZ 02-23-2012 12:47 AM
I have been thinking of getting an Innovate kit also. Please let us know how this one works out.
I'm not sure if you would need a logger with CIS if you have a display. It seems like you could only tune for full throttle, or maybe for fuel economy, since there is only one adjustment and it affects the entire range. I could be wrong though, I'm still learning about CIS.
WPOZZZ 02-23-2012 12:48 AM
At WOT, my AFRs would be in the 9s.
village idiot 02-23-2012 07:35 AM
Yeah, but you're turbocharged. And besides, flames on decel are cool!!!:D
gavinc69 02-23-2012 11:01 AM
I got this a short while ago MTX-L Wideband O2 Digital Air/fuel Ratio Gauge, very easy install, works a treat.
Just had the car dyno'ed and the AFR results from my Innovate and the dyno machine where almost identical (they had there dyno re-calibrated only a few months ago so its spot on) so it does a good job too.
Josh D 02-23-2012 12:13 PM
I'd be curious to see how this works out for tuning CIS as well. For $200, not much to lose!
Ronnie's.930 02-23-2012 12:33 PM
There is only one adjustment in stock trim but you can have your WUR built to be adjustable and then have a much wider range of adjustability.
village idiot 02-23-2012 06:06 PM
I think that'll be the next purchase. Or on of those digital wur(s)........
snbush67 02-23-2012 06:53 PM
You would know for sure if you didn't drive like a 90 year old Asian lady.
WPOZZZ 02-23-2012 09:05 PM
:mad:
It is in the mid nines. Cruising is 14.7 and when I step on it, it drops rapidly. Unfortunately, the o2 sensor is gone so I haven't tested WOT with the fuel enrichment dropped down a notch.
snbush67 02-28-2012 06:52 PM
You aren't even going to attempt to deny this?
2porscheguy 02-28-2012 07:12 PM
Ronnie's930, I'm curious, how does one get a WUR to be adjustable.....is there much involved in doing this? Villiageidiot sorry for hijacking your thread!
Cheers!
Alex
village idiot 02-28-2012 07:41 PM
Cheers!
Alex
No problem! the more people that post in this thread the betterSmileWavy More info is always good:D
WPOZZZ 02-28-2012 09:07 PM
You're just mad because I passed you on that drive with my windows up and the ac on! :D
village idiot 02-29-2012 12:42 AM
And here we go.......:D
WPOZZZ 02-29-2012 04:04 AM
Does this look familiar?
1974 Porsche 914 race car - $1500 (Kailua)
Ronnie's.930 02-29-2012 06:18 AM
Cheers!
Alex
There were severaly threads on this when I did a quick search - here is one:
http://forums.pelicanparts.com/porsche-911-technical-forum/272502-modified-my-wur.html
I am a DIY person, but for this I just sent mine to the WUR guru, Brian Leask.
Another guy, well know on this board, Brian Bodart - RarlyL8 Motorsports, even stocks already modded WURs that you can buy . . .
