993 55 pin DME wires color chart- help!!
I am in the process of installing a Supercharger into my 3.6 conversion car. Engine is a '97 993 Euro Varioram with a 55 pin DME connector. I need to do the wiring of the SC piggyback computer. I have the DME pin-out which allows me to identify into which pin number to connect the wires from the piggyback unit. The problem is that it is impossible to identify which color wire corresponds to which pin number on the DME.
Does anybody has a chart which tells which color of wire relate to a specific pin on the DME connector?
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 02-23-2012, 07:21 PM
what I need is the color code of wires # 7(MAF), 37(12V), 48 (Crank -), 49 (Crank+) and 53 (TPS)
Anyone PLEASE!!
Mario
'15 GT3
Old 02-24-2012, 05:41 AM
Bill Verburg's Avatar
Anyone PLEASE!!
first the above connector is for a US non vram and is not 100% correct for a RoW '96-98 vram motor
on the '96 - 98 RoW Motronic 2.10 vram motors
pin 7 MAF is 0.5 Bl/Gn
pin 37 MFI+Di relay term 87 is 1.5 Re/Wt
pin 48 ESS connection B 0.5 Br
pin 49 ESS connection A 0.5 Wt
pin 53 TVS 0.5 Wt/Gn
Bill Verburg
Old 02-24-2012, 06:20 AM
Thanks Bill!!!!
Mario
'15 GT3
Old 02-24-2012, 06:23 AM
redturbo911's Avatar
I was going to tell you contact bill v for his wealth of info but he beat me to it. Good luck.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 02-24-2012, 09:44 AM
