Day 33: Today I was able to strip the tar off of the front passenger patch piece installed on day 32, clean up to clean shiny metal and use the new spray gun to shoot epoxy over everything! I think it turned out pretty good.
http://forums.pelicanparts.com/uploa...1334670196.jpg http://forums.pelicanparts.com/uploa...1334670212.jpg |
tell us about your plans for sound "deadener" etc.
sounds like "Bi^ch-o-Thane" by W.R.Grace Company...awesome roofing sealant material in rolls...if this is the same stuff, after you peel back the paper, if it touches itself, you will never seperate the stuff...
This will add quite a bit of weight if that may be a concern... Keep rockin'...you are doing great... Bob |
There are cheaper alternatives to Dynamat, Fatmat, whatever... Beware of the tar paper idea, it'll work, but come summer, it'll smell eventually ;-)
Eastwood has a product similar to Dynamat that I believe is significantly less expensive. Also, I can't remember if I read it here in your thread or another, but someone pointed out that you don't have to cover every surface for sound deadening purposes... the larger flat areas should suffice like the squares in between the "ribs" in the floor pans. By using a selective application method, the material will go much further.
I would put down some sound deadener - use it in strips or squares over 1/4 of the floor area to save wt. or entire area if you don't care...
on top of that, you can use a so-called Mass Loaded vinyl (MLV) product (again I encourage you to sic some students on how it all works, esp. any that are interested in the acoustics branch of physics or bioacoustics over in the Biology Dept.) the above is what I am doing, except I only removed part of the factory deadener instead of adding more - the MLV can be lifted out to save some wt. for AutoX or track use NEVER use a roofing material inside the passenger cabin. to make it a concoursmobile, but not one that has modern levels of performance, use coir or horsehair (search on those terms; thread active this week) BTW - buy Frere's book on the 911 and study carefully - it has tons of info in it. |
oh yeh - I like the stuff from Cascade Audio -- they are the only place I've found that seems to have even minimal technical knowledge...
My dad used it on the inside of the door skins of his '61 Austin Healey. It really gave them a nice solid sound when closing... you know, like German cars come standard with ;) I had a flyer in the mail from Eastwood yesterday and I think the Thermo-coustic may be on sale right now. I'll check when I get home from work and let you know. |
BTW - rap on it with your knuckles bare, then add the stuff (mostly in the center) and check by rapping some more
- when the resonance declines in amplitude and the resonant freq. shifts lower you are about done, i.e. you have "done spreaded the Q out" (in Southern) (see how all those courses come in handy)? |
:D Well said. I took a class on Vibrations (no seriously, I know you're laughing but this was for real) in engineering school that dealt with such subjects. I recall quite a bit of differential equations were required to explain it, which quite frankly has long since slipped my mind (not that I was ever that great at it to begin with). Your suggestion is a practical way to know that you have done the job right... And if all else fails, you can always add more.
I liked my Mechanical Vibrations class. The Mechanical Controls Systems class is more of the same sort of fun. But mostly just looking at things in the frequency domain and analyzing the critical parameters that way, then using a computer to solve for time domain response.
I am forever grateful for the grad student way back when who made up the LaPlace transform/inverse transform table. |
Thanks for all the advice about the sound deadening material. I think I am going to go with Eastwood stuff. I never learned much about vibrations as I am a civil engineer but we did study the natural frequency of objects such as bridges in wind loading. Check out the Tacoma Narrows bridge
Tacoma Narrows Bridge Collapse "Gallopin' Gertie" - YouTube |
But I digress... Keep us posted how the Eastwood product works out for you. |
If your a civil engineer and what you build moves, there is a problem. If you are a mechanical engineer and what you build doesn't move, there is a problem. :)
| All times are GMT -8. The time now is 07:00 AM. |
