I also use Ospho or a similar product. IIRC, it is indeed phosphoric acid and some tannins (tannic acids). My understanding is that it drives the chemical Red-Ox reaction that turns the iron into rust -- Fe2O3 * nH2O -- in a reverse direction. It prys the things away from the water or OH "pieces" and then must lock something else onto those ions.
Maybe some real chemists can comment on this(?) Does it change Fe(III) into a different state? But how does it create a zinc coating on the surface of clean metal?? |
It's been a while since I studied unorganic chemistry, but if I recall correctly, what happens when ferrous (III) oxide (i.e. rust) is exposed to an acid, it's being reduced to ferrous (II) oxide, which is black and a much more durable state than Fe(III).
Or, to put it in chemical terms: Fe2O3 + nH+ --> Fe3O2 + H2O |
I think I was able to source a floor pan for just the passenger side!!!
Day 28: I was able to make some progress on the driver floor pan and the rear seat bucket on the driver side!
http://forums.pelicanparts.com/uploa...1332817388.jpg http://forums.pelicanparts.com/uploa...1332817425.jpg I also sprayed Eastwood Internal Panel Coating into the rockers. I sprayed 1 can into each side, both inside and outside rocker with the special attachment hose to get into the entire thing. http://forums.pelicanparts.com/uploa...1332817519.jpg I also was able to grind off a little bit more of the roof http://forums.pelicanparts.com/uploa...1332817688.jpg |
the manf. tells you that it is ok to paint over that black from using the Ospho to convert rust
also found this snippet: Rust converter - Wikipedia, the free encyclopedia compare with: Phosphoric acid - Wikipedia, the free encyclopedia Rust removal Phosphoric acid may be used as a "rust converter", by direct application to rusted iron, steel tools, or surfaces. The phosphoric acid converts reddish-brown iron(III) oxide, Fe2O3 (rust) to black ferric phosphate, FePO4. "Rust converter" is sometimes a greenish liquid suitable for dipping (in the same sort of acid bath as is used for pickling metal), but it is more often formulated as a gel, commonly called naval jelly. It is sometimes sold under other names, such as "rust remover" or "rust killer". As a thick gel, it may be applied to sloping, vertical, or even overhead surfaces. After treatment, the black ferric-phosphate coating can be scrubbed off, leaving a fresh metal surface. Multiple applications of phosphoric acid may be required to remove all rust. The black phosphate coating can also be left in place, where it will provide moderate further corrosion resistance (such protection is also provided by the superficially similar Parkerizing and blued electrochemical conversion coating processes). |
[QUOTE=RWebb;6648996]the manf. tells you that it is ok to paint over that black from using the Ospho to convert rust
I don't believe this at all. I have let the ospho sit and convert rust for the recommended over night period. When I scraped at the black stuff with a screwdriver or went over it with a wire wheel I found rust immediatly under the black layer. That is why I repeat the process 3 to 5 times to make sure I have clean shiny metal. |
it is only for a thin layer of surface rust -- maybe that is the problem; also different manf.s may have different "additives" in their products
personally, I've never used the black layer as a primer; I put a Rustoleum primer over it then a Rustoleum paint why not drop this question in the lap of your graduate students? |
[QUOTE=kkinzli;6649474]
check out Wurth Rust Guard...all you need to do is remove the loose rust & crap...I then wipe down w/ acetone & paint it...it says on the can that the product works BEST on metal that has "tooth" = NOT CLEAN SHINNY METAL...
I have never had a rust problem continue in these areas...the finish is rock hard & does not come off...do you guys know of this paint...?? A 1 step process also... I highly recommend this stuff although it is ~ $70/qt shipped... |
[QUOTE=davidbir;6650378]
Agreed. I know nothing but I think these paint over rust type products are a bit like a bandaid on a gunshot wound.
next idea - find a smart undergrad - maybe in Chemistry - and get them to run some analysis on the different brands -- help them write it up...
if it all works out, in a year or two you will have your first grad. student in the meantime, we can all balance labor input vs. expected longevity |
The Rats younger brother the Black Knight had a huge milestone the other day 250,000 :cool::cool::D:D:)http://forums.pelicanparts.com/support/smileys/wat6.gifhttp://forums.pelicanparts.com/support/smileys/clap.gifhttp://forums.pelicanparts.com/support/smileys/ura.gif
I celebrated by pouring a beer all over the car like I did for 200K http://forums.pelicanparts.com/uploa...1332961420.jpg |
Awesome project. Keep up the good work!
Kudos on keeing the a4 on the road too. My old 97 A4 1.8t went 230k before I put her into a guard rail! I'm positive she would still be running like a champ had I not wrecked her. |
| All times are GMT -8. The time now is 12:52 PM. |
