| Registered |
				check your thermostat when you can
			Apparently they do go bad.  Which thermostat is not like the other? Remarkably, the car never got above 220 in normal driving even on a 95 deg day, and during heavy track use it topped out around 240. So the external cooler must be doing a decent job! So, unless your car is running very cool, if you have the chance, pull the thermostat and test it.
				__________________ '88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" | ||
|  07-11-2012, 01:28 PM |
