1985RedTarga's Avatar
Heater, blower relay? Where to get one?
I think I need a "new' blower relay for my heater. You know, the one that is in the engine compartment for my 85 Targa. Where can one find a good used one with a budget? I saw one for 500 bucks on ebay. Not gonna happen. Any help would be awesome!
Jamie
Jamie
1985 911 Targa
Old 02-26-2012, 08:01 PM
ROW '78 911 Targa
timmy2's Avatar
Not sure which one you need. A part number would help.
Maybe it is among these ones?
Porsche 911 & Carrera Gauges and Miscellaneous - Page 4
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-26-2012, 08:36 PM
Email me with what you are looking for. I have a 3.2 that I am installing in an early car and am looking to sell the engine mounted heater blower from the 3.2. If the relay is part of that I can help you out.
'73 CIS T with a 3.2 on a stand in the corner
Old 02-26-2012, 08:48 PM
schumicat's Avatar
they are always on ebay.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 02-27-2012, 06:52 AM
I meet up with a local Cincinnati Pelican names Pete and we swapped relays. That wasn't it. Now on to the switch.....
Jamie
1985 911 Targa
Old 03-08-2012, 02:33 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Thank goodness it is not the relay, saved a bullet there.
If you are talking about the lever switches those are more reasonable
If you remove it, post it, it may not be broken, just bent. If you hear a click, there should be good if not then it is internal damages.
'85 Carrera Targa
PCA/POC
Old 03-08-2012, 04:59 PM
I don't know, I'm hoping its the rotary switch. We'll see.
Jamie
1985 911 Targa
Old 03-08-2012, 07:04 PM
DRACO A5OG's Avatar
Oh I see.
Well, if you can by pass the rotary switch that will verify it.
Lever switches control the engine fan, the rotary controls the foot blowers via the lever switch and engine fan.
'85 Carrera Targa
PCA/POC
Old 03-08-2012, 11:42 PM
Originally Posted by DRACO A5OG View Post
Oh I see.
**** Jim. Your news doesn't sound encouraging. Damn it. Oh well. I've got a new switch coming I think (used). We'll see.
Jamie
1985 911 Targa
Old 03-09-2012, 10:58 AM
DRACO A5OG's Avatar
Oh no, I meant no harm. If you can remove the seat/s and move away the console. you will see the lever switches, they are two mini snap-action switches in one like this:
very fragile and get alot of dirt and debris and conncected to the wire loom next to the access panel of the coupler.
'85 Carrera Targa
PCA/POC
Old 03-09-2012, 11:53 AM
Yeah, that's them. I've got the housing off and I cleaned up the contacts on those guys. They do make contact when they are supposed to. It's just that nothing happens, thus why I was thinking it may be the rotary switch. If replacing that gets me no where, maybe I should replace the lever switches?
Jamie
1985 911 Targa
Old 03-10-2012, 04:44 AM
1984 911 Targa - "Sabine"
Skip1's Avatar
Previous Auto heater problem
Jamie,
I just resolved a slew of headaches on my auto heater in my '84 Targa RoW. In the end it was a combination of the engine blower fan not functioning as well as the relay. We had a fair bit of discussion on the issue on another thread if you don't mind reading through a lot of stuff - could be useful.
Auto Heat Query
Skip
Skip
1984 (RoW) 911 3.2 Li Carrera - "Sabine"
2011 Cayenne S
Old 03-10-2012, 10:49 AM
DRACO A5OG's Avatar
I may be wrong but he and I have the standard heater controls, auto heat control fix may not apply. Hope those new snap action switch works for you brother!
'85 Carrera Targa
PCA/POC
Old 03-10-2012, 04:32 PM
Thanks guys, but I have what Jim has and that's the manual heat switch. Have one coming and hoping, praying that this is the issue. If not, you'll hear me *****.
Jamie
1985 911 Targa
Old 03-11-2012, 08:18 PM
Did you check the fuse neat te relay in the engine compartment?
1986 3.2 to 3.4 conversion
Old 03-12-2012, 09:47 AM
Skip1's Avatar
Fair enough Draco, my thought was "if it wasn't the control unit", then the engine area appears to be the most likely culprit - hope it's a simple fix.
Skip
2011 Cayenne S
Old 03-13-2012, 05:19 AM
