Enthusiast
jrolstin's Avatar
915 Question - What's this sensor?
Hey guys, I had a question... what is the sensor in this picture, and can I order a new one from our host?
Regards,
Jonathon
Jonathon
1982 911 SC
www.avrmotorsports.com
Old 03-02-2012, 05:10 AM
speedo.
206 637 4071
Old 03-02-2012, 05:23 AM
Enthusiast
jrolstin's Avatar
Is it possible to buy a new one? It looks all melted kind of...
Jonathon
1982 911 SC
Old 03-02-2012, 05:30 AM
schumicat's Avatar
yes. but yours may just be dirty. it looks unfinished on that side even new.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-02-2012, 05:34 AM
Walt Fricke's Avatar
If your speedometer was working, don't bother getting a new one.
If you cut the wire to pull the transmission, you can just reconnect the two wires. Doesn't matter which wire connects to which.
The sender is a reed switch, which closes each time one of the eight magnets inside the transmission passes by it. Closing the reed switch grounds a circuit. You could check its function easily enough with an ohmeter and a magnet.
Otherwise, when you clean the oil off of the tranny, it should clean the wire enough that it doesn't look decrepit.
Old 03-02-2012, 05:00 PM
