Speedometer Problems
1979 SC
Speedometer ran when I first got car, then had the transmission re-built (by Gary Fairbanks in CT) and two years rebuilding the engine etc... and it now doesn't work.
I got a new sensor, and just had my speedo re-built by North Hollywood.
I have continuity from sensor H wireattachment to the two brown wires at back of speedo.
4 wires attach to the back of speedo
1) have power on red/black when ignition switch turned on and attached to +
speedometer contact A is left empty
2) the green sensor wire goes to 31b and
wires 3, the other sensor wire and wire 4, a ground wire, goes to the - .
Could the transmission be missing whatever the sensor picks up?
Can I check the sensor ? Should there be continuity between the two sensor wires?
please help!!!!!
dog
Old 03-03-2012, 04:13 PM
Anyone???
Old 03-04-2012, 05:48 AM
6 cylinder symphony
Here are my guesses:
1) Your sending unit is dead, or installed backwards. It happens.
2) When NHS re-did your speedo, they put it together wrong, and the needle is stuck. I need to send my speedo back to them, since the needle sticks under 20 mph.
I can't remember how you check the sensor. It's a magnetic switch. I thought I remembered a thread where you could remove it and clean underneath it? Can't remember.
Finally - are you sure you have it wired right? NHS sent me a nice little diagram when they re-did my speedo. If I can find it, I'll post it.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 03-04-2012, 06:51 AM
76 911S Targa
Just a thought. If this were my car, I would pull the speedometer and connect the input wires to a voltmeter to see if a voltage is generated when the car is moved. A helper could watch the meter while you are driving or vice versa. My guess is there is a disconnect between the sender and your speedo. This would be a way to check it. North Hollywood Speedo has a great reputation so I think the problem is with the car rather than with their repair. If you have a friend with a similar model you could swap speedos to test for function that way.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 03-04-2012, 06:53 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Speedo.
Originally Posted by Number1_dog View Post
1979 SC
please help!!!!!
dog
Hint: Chip damage prevention.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-04-2012, 07:32 AM
schumicat's Avatar
the sender wiring connects under the panel in the rear floor. see if those wires are connected. the speedometer can be tested by unplugging and rapidly touching the 2 wires from the speedometer together. that should make the speedo needle move. the sender attaches to a recess on the trans on the passenger side and is held on with a small bolt. correctly installed a rough surface faces out. if a smooth plastic surface faces out is it installed wrong.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-04-2012, 08:22 AM
Roger Shultz's Avatar
To verify the operation of the sensor you must use an ohm meter instead of a voltmeter. If the sensor magnetic switch is working properly with an ohm meter across the two wires which you can access in the tunnel, you should see the resistance reading go from zero (a short) to infinity as the wheels are turned. You can jack the car up in the rear and do this or simply move the car while a helper looks at the meter to see what it is doing.
If that open and shorting action does not occur, then you will know in which direction the problem is occurring.
Former rides
1961 356B 1600 (paid $800 for it in 1968!)
1968 912 soft window brown Targa
1980 911SC Targa triple black
Old 03-04-2012, 08:26 AM
Thanks Rodger, this is what I was looking for!
Old 03-04-2012, 03:34 PM
related to my 79:
a few weeks ago, the odometer on my 79 stopped working but the speedo worked fine. i popped the speedo out and took it to a shop in the area who other pelicans have used for repairs. he was familiar with the problem...replaced the broken gear and recailbrated it. yesterday i popped it back in the car and went for a drive. I got up to about 15-20 MPH (estimated) in the neighborhood, but the speedo and odo were not working and went back home. i relooked at the wiring and it was how i pulled it, but went ahead and swapped the 2 brown wires in case i wrote it down wrong when i poped it out. I still did not work, and rewired to as it as before (in the distorted picture). i figured this would be plug and play since i didn't do anything else in the transmission/sensor and i assumed the speedo is still getting a signal. Any thing I should look at? which wires are the input wires to check w/ ohm meter? could the speedo be sticking?
Charles
88 911 Cab
74 TR6
88 CRX Si
79 930 #632 (sold her and survived her)
Old 05-01-2012, 08:37 AM
