idle bypass question
When attempting to lower the idle slightly on a 3.2 with B&C jumpered the idle bypass screw is already maxed out to the clockwise position which does not allow the idle to be lowered. What is this telling me?
"Charlie don't surf!" |
Member 911 Anonymous
When you jumpered B & C did the idle speed change? If not, you are not properly jumpered. When I first tried it I was so scared I did not seat the wires in all the way and I was turning going no where fast.
Check it again and verify proper jumpered positiion and fully seated then adjust. DME will adjust automatically if not jumpered.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thread Tools | |
Rate This Thread | |
