Need help locating a condensor for a 2.2 S dizzie
My '69 T has an Bosch 007 distributor - the chart shows it as a 2.2 version. At some time in the car's history someone has taken out the CDI box (I am assuming that it had one) and it is now running with a coil/condensor package. Our host has not been able to find me a condensor so I thought I'd put a photo out there and see if anyone else has this setup and if they can point me in the right direction to find one - or maybe I need to rethink the system?
This is it: ![]() Thanks for the help
1963 356C race car (SOVREN, VRCBC) 1969 911E Coupe (bought from original owner) 1969 911T Coupe tangerine original paint (sold) |
Tpickstone,
I may have one of those. Any numbers on it that might help? Dana |
Dana,
I'll pull it out again and have a look for numbers on the condensor. Thanks, Tim
OK, the condensor has no numbers on it and it is 1 inch long and 3/4 inches in diameter.
Thanks again for any help.
Go to your local NAPA store (or similar) and see if they have Echlin or Bluestreak replacements.
Or...how about a Co-op (for tractor parts)? Any automotive type condensor will work...all it does is reduce the spark across the points when they open. Bob
Bob Hutson |
French Import
Some VW aftermarket shops may have the condenser you need.
There should be a value in Microfarad (μF) that needs to be matched, otherwise any other form factor will work.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
If you think either of these will work, I'll send one to you.
Dana
