Dept store Quartermaster
Direction of distributer rotation? daddy needs help again
Well, tonight I install the new Magnecore wires, plugs etc.. in my '77 930. I intially checked and marked the #1 plug wire location on the old cap then looked to see where #6 was in relation to establish direction of rotation. Conclusion was that it is clockwise. Well then I was thumbing thru my technical manual and it says that 78 model 930's have a counterclockwise rotation. I could not find my '77 model in the manual. I now am fighting in my head as to whether I looked at it correctly the first time or not. You see in the manual it kind of stated the 78 models counterclockwise rotation as if it were a change but without really saying so.
Why not just turn your fan with a wrench (as if you were adjusting the valves) & watch which way the rotor on the distributor turns? That should be the best way to tell.
regards, jlex.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Oh, don't get me wrong I can think of many ways to figure it out. I guess my question was more a matter of interest in why they would, if they did, change the rotation after '77. But I do appreciate your replay, thanks.
Irrationally exuberant
This is going to get me in trouble with the SCWDP but I believe the distributor rotated backwards (CCW) during "those mixed up SC years" and returned to normal (CW) after that.
-Chris |
