Certified User
billjam's Avatar
3.6 cylinder head temp sensor resistance?
I am in the process of setting up a MS3X for my 3.6 engine and I need the calibration values for the CHT sensor if anyone has them. The sensor is the same for all '89 to '94 3.6. I am using the CHT sensor for warm-up controls.
It is the usual three resistance values at around freezing, boiling and somewhere in between.
I'm working on this away from home, otherwise I'd yank the sensor and measure it myself.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 03-18-2012, 11:48 PM
Chain fence eating turbo
Sub'd for outcome of how good it works for you.
I can give you the '87 specs if you need, but it won't be until I get home from work today.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 03-19-2012, 06:41 AM
Certified User
billjam's Avatar
Cory,
In the absence of any later model numbers, I'd appreciate your numbers from an '87 sensor just to keep this setup moving along. I can't believe they'd be much different.
I'm pissed off that I didn't think to measure this before I installed the sensor.
At least the engine is still on a stand so it's not a major job to pull it out and measure it. A great little job to look forward to when I get back home.
Bill
2024 Macan S
Old 03-19-2012, 07:16 AM
There is some information at this link here: Cylinder head temperature sensor testing Porsche 911 1984 1989
Thanks, Paul
1979 SC
"A man of many projects and too many hobbies"
Old 03-19-2012, 07:26 AM
Originally Posted by billjam View Post
Cory,
No problem. I am in the same boat. Can't seem to get a workable TPS for mine.
What are you using if you don't mind?
Old 03-19-2012, 07:27 AM
You know Bill, you might want to actually measure since the book gives a range.
I have no problem getting it though, just throwing that out there.
Old 03-19-2012, 07:28 AM
IIRC I used the default Saab Bosch in the sensor list and it pretty darn close. It does not need to be dead on you can play with the numbers alittle in the warm up area.
Old 03-19-2012, 07:37 AM
Certified User
billjam's Avatar
I never thought to look in the manuals for the CHT resistances. I'll check.
For TPS, I am using the standard sensor that came with the Triumph Daytona 675 throttle bodies that I am using. I haven't calibrated them yet, but don't expect any problems. More build pics in this thread.
Bill
2024 Macan S
Old 03-19-2012, 07:43 AM
Certified User
billjam's Avatar
Thanks, that's an interesting link Paul, however the numbers for resistance are a bit hard to decipher.
They may make more sense when I have something to compare them to.
Bill
2024 Macan S
Old 03-19-2012, 07:49 AM
Certified User
billjam's Avatar
Just found this in the 964 manual. Thanks for the hint Cory.
I'll use these numbers for now and fiddle with them later if I need to.
Bill
2024 Macan S
Old 03-19-2012, 07:55 AM
The range is huge. Maybe it doesn't matter much?
On mine, I was going to take the median for each value.
Old 03-19-2012, 08:11 AM
