For those interested check out what is called a "slip sheet" technique for installing typically laminates. By using a non glued piece of material between glued/prepped materials you can locate exactly what you are going to glue together with contact. Line the pieces up / remove carefully the slip sheet or partially remove it and begin making your piece contact. Folks who do alot of veneer work can get those diamond shaped pieces to fit truly anywhere.... or vinyl/leather interior Porsche parts.
Old 11-27-2013, 06:59 PM
Immature Member
dentist90's Avatar
Originally Posted by Newbrunswicktod View Post
In non-sunroof cars there are bows that keep the headliner tight up against the roof. Can anyone explain how the headliner in a sunroof car is kept up against the roof? I'm getting ready to tackle the job. Thanks all.
The headliner is glued/clamped to the frame surrounding the sunroof opening. This supports the headliner enough that it doesn't sag. When the interior dome lights, coat hooks and sunvisors are put back in it tensions the headliner even more. It's not actually firmly up against the roof except around the edges.
Trickiest part was the rear corners near the parcel shelf. There are wire rods that are used to tension the back corners and they have to be sewn into the headliner
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 11-27-2013, 08:21 PM
Hey Dentist90. Thanks so much for the clarifacation.
Todd
Old 11-28-2013, 03:03 PM
Great work. Thank you for the inspiration
Old 11-28-2013, 04:44 PM
