For those interested check out what is called a "slip sheet" technique for installing typically laminates. By using a non glued piece of material between glued/prepped materials you can locate exactly what you are going to glue together with contact. Line the pieces up / remove carefully the slip sheet or partially remove it and begin making your piece contact. Folks who do alot of veneer work can get those diamond shaped pieces to fit truly anywhere.... or vinyl/leather interior Porsche parts.
Immature Member
Trickiest part was the rear corners near the parcel shelf. There are wire rods that are used to tension the back corners and they have to be sewn into the headliner ![]()
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
Hey Dentist90. Thanks so much for the clarifacation.
Todd |
Great work. Thank you for the inspiration
