jjwood's Avatar
915 Custom gearbox questions
Here's the "projected gears"
1st --- 11-35 3.18
2nd --- 17-34 2.00
3rd ---
4th --- 23-29 1.26
5th --- 26-26 1.00
Here's the questions
a) what would you suggest as a good 3rd gear choice?
b) given 8:31 R&P and 315/35x17's what should I anticipate top speed in 5th at 7300RPM?
c) does anyone have a "used" contact source for the suggested 3rd gear choice?
thanks,
Jeremy
1971 911 Wide One 2.7
2012 911 Cabriolet
2011 Cayenne S
Old 03-21-2012, 10:58 AM
Peter Zimmermann's Avatar
Jeremy; you will have to plot your gear ratios on a chart that shows rpm drop between each pair of gears. Then you have to figure out why you need those ratios (AutoX, slalom, specific course time trial, etc.), and decide if they will work. In other words, you must have a reason to do a gearbox a specific way. After spending time with gear charts, found in factory manuals, you will have to measure the OD of your rear tires, and see if there is a significant difference in size from what was stock on your year car.
Keep the Shiny Side UP!
Pete Z.
Old 03-21-2012, 11:35 AM
Bill Verburg's Avatar
1st --- 11-35 3.18
2nd --- 17-34 2.00
3rd ---
4th --- 23-29 1.26
5th --- 26-26 1.00
thanks,
As Pete pointed out it depends on what you want from the trans
the 26/26 5th gives an awfully low top end of ~139 and some really funky drops to boot
I took the liberty of making a few changes
I still thank that its hard to beat the gearing on an SC/RS
Bill Verburg
Old 03-21-2012, 12:01 PM
Dang you're quick Bill
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 03-21-2012, 01:27 PM
Bill, awesome job! After I answered the OP I hoped that you would see this thread!
Pete Z.
Old 03-21-2012, 01:30 PM
One of the perks of retirement
Bill Verburg
Old 03-21-2012, 02:15 PM
Racer
winders's Avatar
Bill,
What software are you using to generate those charts? I would like to get that infor for my transmission....
Thanks,
Scott
Old 03-21-2012, 02:37 PM
kandhmfg's Avatar
I have messed around with this site. Fairly close. Plug Tire size or diameter, RPM, R&P Ratio and Gear Ratios. Easy to copy and paste into excel.
http://www.f-body.org/gears/
Old 03-21-2012, 03:30 PM
