Chain fence eating turbo
A GM TPS that rotates the same direction as the Carrera TB?
The GM TPS I bought turns the wrong direction. I hate to cut open the other side to make it work.
Seeing if anyone knows of a GM one since I already wired in the GM connector into the harness.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
A TPS for 3.2 Carrera Intake
This photo is from the SDS website. I ordered one -- CCW rotation looking at the shaft in the throttle housing -- and installed it per the second picture. The phenolic block is 3/8" thick to provide the necessary standoff and was machined on a table saw.
![]() ![]() Search the 911 forum for user Jim2 -- he did the same thing in aluminum. Brian |
When looking at the shaft side, mine turns clockwise.
The GM one turns counter and unfortunately, I already wired the GM connector.
Navin Johnson
On some engine management systems you can set the TPS value as an increasing or decreasing value... i.e. 0-5 volt or 5-0 volt...
Take a look in the software for the ECU whether you can do this.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Yeah, understood, but the GM TPS I bought turns CCW when looking from the shaft side which opposite the Carrera - meaning, it won't work unless I cut open the other side of the TPS so it'll work.
Just wondering if anyone knew of a GM TPS that turned with the Carrera TB shaft. I believe the Audi and BMW ones turn the right way?? Last edited by Tippy; 03-22-2012 at 05:17 PM.. |
