Hello, IŽll try this one too
starting to collect information before to test and blow engine ![]() Have anyone made combination of early MFI with turbo without having factory super rare pump So what is needed to do or what kind of boost effected equipment is need to adjust the rack related on barometric unit? Will be were graefull of any information ![]() Pekka from middle of snow (Finland) |
Max Sluiter
I think the factory basically made it so that the barometric cell "saw" the compressed air from the turbocharger instead of the atmosphere. They had a specific space cam in the pump too.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Max Sluiter
![]() Porsche 934.5 Brumos Racecar_ 098 by Max_911S_fahrer, on Flickr ![]() Porsche 934.5 Brumos Racecar_ 105 by Max_911S_fahrer, on Flickr
So that was also mysolition thinking, but has anyone allready any formulas how much the movement of barometric axle should move when boost /10 psi is effected(0,1bar here in metric system)
I was thinking upwise sort of atmosphere/pressure actuator like in exhaust boost adjustment But how much movenmet imm / 0,1bar of pressure this is the dark part of room ![]() the special space cam ifromation also would be cood otherwise I have just to test diffrent type of and try to find something
Chain fence eating turbo
Sounds like "Flieger" has it under control but you can also ask in the 930/911 turbo section.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Max Sluiter
I guess you could just do trial and error. That is how the factory did it with the 917-10 turbo system. But that is kind of expensive.
