CT Mike's Avatar
Temperature Gauge Fluctuating
Once the engine is warm my temp gauge registers temperature but the needle bounces around, about 1/4 inch. It's never steady. Im assuming this isn't normal. Sound like the gauge or a sender? Thanks for the feedback.
Old 03-26-2012, 06:28 PM
ROW '78 911 Targa
timmy2's Avatar
Loose connection on either end?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-26-2012, 07:30 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Disconnect the negative side battery for safety.
Pull gauge, and clean/polish the connectors. If connector is loose tighten it.
+1 go to the sender/switch and clean/polish as well.
If this does not fix it then it may be a bad sender or gauge. Before buying a gauge, see if a neighbor Pelican can lend you his to test. An excuse to meet for Beer and talk 911 shop
'85 Carrera Targa
PCA/POC
Old 03-26-2012, 10:15 PM
