Oil line loose 3.2
My oil line hose from oil tank turns on the crimped pipe end pretty easily , is this normal? I would think that if crimped tight , it should not turn. I'm not sure if it has been leaking, since I had leaks else where that I have now fixed. If this is not normal hopefully a local shop can crimp a new hose on for me .Thanks for your input.
Not normal. You need a new hose.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
![]() Perhaps you can find a local shop to Re-Hose your Feed to the Thermostat as this.... ![]() Just be careful they use the correct crimp jaws and crimps. Most have Crimps & Jaws that are too long. Len
fix/replace asap!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Not normal. and getting that other end off from the thermostat is often a real hard chore.
Either get a new hose, or see if there is a local shop that can get a good crimp on your fittings. It is metric hose, and be 100% certain it is done right. It is under pressure, and could empty the oil system in seconds if it fails.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
A new hose is not that expensive. Beats getting it repaired.
Great , thanks for the help ! Hopefully it won’t give me that much trouble breaking it loose from the thermostat.
83 911 Production Cab #10
So I carefully slice the nut with a Dremel and use aftermarket replacement nut. https://www.pelicanparts.com/More_Info/ERMP0170000.htm?pn=ERMP-0170000&bt=Y&fs=0&SVSVSI=803 Never leak after it was replaced. I'll post pictures tonight.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
On my 1985 I replaced that exact same oil line for the same reason, it was seeping oil. I started soaking it with penetration oils for a couple of weeks before I tackled it. With lots of cussing and fighting I got it off and did not hurt any threads on the thermostat. Many people have removed the thermostat from the car, and put it in a vise to have better access to it.
Read the many threads on the board about how others have done it. Good Luck!
