LinkBack | Thread Tools | Rate Thread |
Installing TPC Supercharger kit on 993 conversion 911- it won't start!!!
I am installing a TPC supercharger kit on my '76 911 with '97 993 Euro Varioram engine.
I finish with the installation but the car does not start. The starter cranks, but it seems that there is no fuel going to the engine. I noticed that when I turned the ignition on the fuel pump does not starts. If I recall correctly, the fuel pump starts working as soon as you turn the ignition on, right? I checked the fuel pump relay and there is power on terminals 86 and 87. The car was working perfectly before disassembled for the installation of the SC. I did removed the engine from the car, so maybe I forgot to connect something? I reviewed everything and does not seems to be the case, but there is clearly something wrong. Can somebody help me in tracking the problem with the fuel pump. I guess if identify the reason why the fuel pump does not get any power, I will be on good track to solve this issue. Thanks
Mario '76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger '15 GT3 |
Not sure what i did, but it started! I still don't hear the pump when ignition is on, though. I am positive before I used to hear the pump as soon as I turned the key.
One thing I noticed is that when ignition is on, the ISV valve is making some humming noise. Is this normal? I now have to install the seat and take it for a test drive. I installed a Head Temp Sensor and at idle it sits around 250F, is this ok? Thanks
Mario,
I expect that you either have an issue with your head temp sensor or your engine is running way too hot!!!! 250F is too hot. Your engine temps should be running somewhere between 180F-210F typically. 220F is hot, 230F is too hot....................250F is way too hot!!!! regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
If you are checking the head temp, 250 is fine at idle....250 oil temp is too hot.
1986 3.2 Carrera |
Ok, back zero ! Now, it wont start again.
It run well. Then, i was letting it idle to check if the additional fuel injector that comes with the kit and the engine stopped. I thought i have run out of gas since it was very low on fuel, but i poured more gas and it is not starting. I suspect there must be somethig wrong with a ground connection somewhere. I seems that no fuel is reaching the engine. I jumped the fuel pump relay betwee 87a and 30 and the pump would not start. It has the same symptons as when I posted this thread, but know I know that it was working ok. I did not do anything other than running out of gas!!! Any hints?
Mario '76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger '15 GT3 Last edited by mmasse; 03-25-2012 at 11:40 AM.. |
Ok, i found that there was a blown fuse on the 12v line going from the CPU to the + of the battery.
Now the questions is: why did it blow?.
Mario -
Depending on how you wired your 3.6L conversion, the fuel pump may, or may not come on when you turn the key to the "ON" position before starting the engine. On my '74 w/a 2.7L CIS, this is how it was originally wired. I would turn the key to the "ON" position, hear the fuel pump hum for a second or two, then turn the key to the "START" position to start the motor. The fuel pump would run continuously as long as the key was in the "ON" position - which made me nervous because in the event of an accident, even if the motor quit, the fuel pump would still be running, potentially pumping fuel in a potentially bad situation. When I did my 3.6L conversion, I wired the pump into the conversion harness from PMS - directly to the DME I think. Now the pump does not run unless the motor is turning 200 RPM (I think). So it starts to run when you hit the starter motor and immediately quits when the engine stops spinning. Not sure if that helps or not. . . Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
I have the Instant G kit. I has been a long tme since made the conversion, and I don{t remember how the wiring was setup.
Does anyone has the harness wiring instructions from Timmins to refresh my memory? Thanks
double check from which 12V post in the fuse box where you pull 12V for the fuel pump (the DME computer applies ground to complete the circuit for the pump). The DME will only give ground for the pump when it "sees" movement from its crank position sensor.
Sometimes the 12V+ post in the fuse box can be something that doesn't get power when the engine is cranking ..... Put a test light on the post under cranking to make sure. This might cause starting problems, if your fuel system doesn't hold pressure. Also, you could check that your crank position sensor is adjusted properly. I think it is 1mm gap, but you'll need to verify elsewhere on this site. There are many threads providing the information about the gap.
1971 RSR - interpretation |
