no/low boost, please help
I am having problems, A friend and I made some headers for my 76 turbo and then i put a correctly sized garrett to4e turbo on my car, I have very little boost(<5 lbs @ 6k), there is a small but very minor leak in my exhaust, no leaks in my intake tract, and the wastegate is closed, i even took off the vaccum line to the wastegate. The turbo is brand new. The headers are 1 5/8 primarys and 2 1/2 secondarys.Is there a possibility that the turbo is bad??? Any ideas???, i have been messing with this for a week now and want to start beating something
PLEASE HELP
Fix the exhaust leak.
Dean |
Yes, fix the exhaust leak but I'd also take a look at the wastegate. It's one of the most likely places for boost problems to originate. If everything else checks out, pull of the wastegate and check the diaphram.
Bruce Herrmann 97 C4S '04 330i '08 Cayenne S '07 4.8 X-5 |
You do not have permissi
Just a thought, if the headers are massive, there might be less inertia built up in the exhaust stream to spool up the fan. I don't think that would be the area to enlarge.
99% chance wastegate-piston is leaking...take off the wastegate and take a look...alse, check out intake for leaks, you might be making boost but it all leaks out,
Thank you for your time, Last edited by beepbeep; 04-28-2002 at 05:14 AM.. |
