no/low boost, please help
I am having problems, A friend and I made some headers for my 76 turbo and then i put a correctly sized garrett to4e turbo on my car, I have very little boost(<5 lbs @ 6k), there is a small but very minor leak in my exhaust, no leaks in my intake tract, and the wastegate is closed, i even took off the vaccum line to the wastegate. The turbo is brand new. The headers are 1 5/8 primarys and 2 1/2 secondarys.Is there a possibility that the turbo is bad??? Any ideas???, i have been messing with this for a week now and want to start beating something
PLEASE HELP
Old 04-27-2002, 12:11 PM
Fix the exhaust leak.
Dean
Old 04-27-2002, 07:39 PM
GIBSON's Avatar
Yes, fix the exhaust leak but I'd also take a look at the wastegate. It's one of the most likely places for boost problems to originate. If everything else checks out, pull of the wastegate and check the diaphram.
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 04-27-2002, 07:43 PM
You do not have permissi
john70t's Avatar
Just a thought, if the headers are massive, there might be less inertia built up in the exhaust stream to spool up the fan. I don't think that would be the area to enlarge.
Old 04-28-2002, 04:43 AM
beepbeep's Avatar
99% chance wastegate-piston is leaking...take off the wastegate and take a look...alse, check out intake for leaks, you might be making boost but it all leaks out,
Thank you for your time,
Old 04-28-2002, 05:11 AM
