Author of "101 Projects"
Wayne 962's Avatar
What is Wayne Building - Part 9...
Here's something I thought of the other day while at the swapmeet in Anaheim. I need a new desk clock. I know that the old 911 and 356 clocks work using a coil that winds a spring-loaded clock every 45 seconds or so. This type of clock can be easily run on a battery. I've always liked the look of the 356 clock, so I found one and had it adjusted / repaired. Then I bought a 356 piston (I think it was $2). My buddy, Erich bead blasted it, and cut a hole in the center. Add the clock, a seal, some batteries, and a 356 / 550 4-cam connecting rod as the base, and you have a really neat desk clock!
-Wayne
Old 03-28-2012, 01:45 AM
'89 944S2
Very nice!
Greg
Old 03-28-2012, 02:14 AM
Series900's Avatar
I approve.
Damon @ SERIES 900.com
Sunapee NH
several 911 variants
Old 03-28-2012, 05:26 AM
Been There Done That
very cool
Old 03-28-2012, 05:51 AM
Driver
Noah930's Avatar
I'm sorry. Shouldn't this be on the 356 forum?
j/k Very cool desk clock.
1990 Black 964 C2 Targa
Old 03-28-2012, 05:58 AM
Champagne on Beer Budget
HelmetHead's Avatar
Awesome! I've got a couple of clocks and some old 3.3 pistons laying around...Hope you don't mind me copying your idea
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 03-28-2012, 07:20 AM
Porsche Doc's Avatar
Cool Man!
Thanks!
Don Ramsay E Mail: aircooledclassicsporsche@gmail.com
The father of 964 Backdating!
www.aircooledclassics.co
www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/
Old 03-28-2012, 07:44 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Someone has too much time on their hands....LOL
Old pistons have been used for decades as pencil holders....ashtrays..and other wierd uses....but Wayne...I believe you have come up with a new one....Grats.
Bob
Bob Hutson
Old 03-28-2012, 07:57 AM
Wayne 962's Avatar
I tried to find a 930 flat top piston, and I couldn't easily find one at the swap meet (none where I could buy just *one*). The 911 clock is a little bit bigger - I'm not sure if it would fit in the 3.3 piston, but it's worth a try. If you do use the 911 clock, then try to get the clock that runs with the little coil in the back. I'm not sure which year they made the change, but I believe that the battery life will be really good on this.
I like the 356 clock because it has twelve numbers, unlike the 911 and 912 green-faced clocks.
Thanks for all the kind words. On another note, the 935 full-sized model construction continues!
-Wayne
Old 03-28-2012, 11:45 AM
nice clock..
any info on / about the car modell.
Jagermeister... 1:18 ?
never seen one that large..
Rika
Old 03-28-2012, 11:52 AM
Designer King
Paulporsche's Avatar
Love it!
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 03-31-2012, 06:28 AM
