Arrow Sound Video Preview; M&K with RARLYL8 Headers
YouTube - Porschef.wmv
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 03-14-2011, 01:33 AM
Organ Donor
zimmer266's Avatar
Nice.
Old 03-14-2011, 01:38 AM
Targa Time's Avatar
Quite the professional presentation. Car sounds awesome! Hope that mine runs that good when done.
I noticed how clean your firewall is. Have been researching this forum for ways to remove the glue. So far no easy answer without removing the paint. What did you do.
By the way, hope you faired the Tsunami without harm.
Old 03-14-2011, 06:54 AM
I removed the glue with 3m adheasive remover. I then sanded it in rough spots down to the paint surface, I shot a base coat of GP white over the old paint.
No harm here from the Tsunami, thanks.
Shane
Old 03-14-2011, 10:43 AM
Zeke's Avatar
Sounds like you have a little air getting in the exhaust system. I try to mate the flanges and then use Wurth exhaust seal.
Old 03-14-2011, 11:01 AM
Arrow
Milt,
Thanks for listening. Do you think the air is getting in at the heads or at the muffler flange? I have a loose stud at the #3 head so that is probably where it is comming in at, I guess I'll have to drill and insert.
Do you think this is why I am getting the popping sound on decel?
Thanks, Shane
Old 03-14-2011, 12:03 PM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
Bringing back a lot of memories of my old '74 Targa, looked exactly like yours, polished wheels, silver bar. Miss that car, it was a blast.
Exhaust sounds great, nice vid.
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 03-14-2011, 03:40 PM
Senior Advisor
James Brown's Avatar
Popping is no doubt from the carbs as they go rich on deceleration, normal and sounds good!
08 Cayenne Turbo
Old 03-14-2011, 04:16 PM
Porsche Crest
James,
Thanks for the confirmation.
Mat,
I like the classic style opening front vents and the backdated chrome look. I have a bit of ECE (Early Car Envy). I think I am done messing with this thing, it is about right where I want it. Perhaps some bigger brakes in the future.
Shane
Old 03-14-2011, 05:01 PM
Zeke's Avatar
But the unburned fuel can't ignite w/o air.
Old 03-14-2011, 06:15 PM
flat6pilot's Avatar
I thought it was when it went too lean it pops on decel.
Great sound though. I love my M&K 2in2out.
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 03-14-2011, 10:00 PM
Senior Advisor
woops yes, lean
08 Cayenne Turbo
Old 03-14-2011, 10:18 PM
spence88mph's Avatar
Awesome sound!
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 03-15-2011, 03:10 AM
cycling has-been
bkreigsr's Avatar
Does Brian incorporate any slip joints to allow for expansion and contraction? That might be the source of the air before its fully up to temp. Bill K
Old 03-15-2011, 06:16 AM
Home of the Whopper
Whatever!!
Nice video. Thought I was watching top gear at first. What a beautiful place to live.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 03-15-2011, 06:33 AM
Crotchety Old Bastard
RarlyL8's Avatar
Nice!
Yes there are slip joints at the merge collectors to allow the system to expand and avoid cracking. Everything should settle out after a few heat cycles and will seal up when warm.
Old 03-15-2011, 06:44 AM
Formerly known as Syzygy
Canada Kev's Avatar
That sounds awesome! Notice any droning at all?
So, if this is the preview, when should we expect the main event?
Kevin
Old 03-15-2011, 07:45 AM
I likey.
Lindy
Old 03-15-2011, 08:10 AM
Porsche Crest Thanks for the Comments!
The main event will probably be just more of the same. This was my first attempt at a video ever. My cameraman (son) did quite a good job but is still a little shaky. We took about 40 minutes of video for this 2 minute production. None of the in car camera was good. So I plan on making another video with a little more in car camera.
I had produced the video with a backing track of "Gallows Pole" by Led Zep, but YouTube rejected it and removed all the sound, so I had to post this one. I guess I should have used "Jessica" as a backing track.
No drone...Its wierd, if you notice in the second clip I am cruising at about 2500rpms and that was where I had droning before with the SSI's. Now, with the larger pipes I do not notice any droning.
I think in the beginning of the video when I am backing out you can hear a little air from the merge, but like Brian says once this thing is warm it is tight. The design and the welds of these headers and muffler are first rate. And no ticking when its cooling down like with SSI's.
Old 03-15-2011, 10:51 AM
Canada Kev's Avatar
Did you get the heater boxes for the headers?
Kevin
Old 03-15-2011, 11:13 AM
