Harpo's Avatar
RSR strut modifications
I want to weld on the double shear brackets, not because the spindles have been lowered 28mm or for any reason other than they look cool. My spindles have only been raised 11mm will this be a problem?
Old 09-09-2017, 09:19 AM
Harpo's Avatar
Here is the piece I want to weld on to the bottom of my struts
Old 09-10-2017, 05:26 AM
Under the radar
Trackrash's Avatar
Are you going to use the tie rod end bump steer kit? Mock it up and see if there is room for your bracket.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-10-2017, 01:17 PM
disband
juanbenae's Avatar
elephant has a great system of stacking shims to level the tie-rod very efficiently. there's real no sense to just space the new mount the distance of the tie-rod end with no adjustment opportunities after that. chuck will not be thrilled, but his bump-steer shim method could be replicated if you looked at one closely.
Old 09-10-2017, 04:15 PM
