Help w/ Another Part ID
OK, this is an electrical line w/ connector coming into the engine bay from under the cover plate on the driver's side. Obviously not connected to anything...
Old 04-06-2012, 03:13 PM
ROW '78 911 Targa
timmy2's Avatar
Looks like the WUR connector for the 3.0 engine in your car.
I'm guessing your car may use a throttle lever inside for cold starts and doesn't have a WUR?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-06-2012, 03:42 PM
ROW '78 911 Targa
timmy2's Avatar
It's the black connector on my WUR.
Dennis
Old 04-06-2012, 03:52 PM
No, here's a shot of my WUR with all connectors. This is something else?
Old 04-06-2012, 05:23 PM
The cold start valve has that same connector - and the wires going to it are yellow.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 04-06-2012, 05:36 PM
ROW '78 911 Targa
timmy2's Avatar
Cold start valve and the safety switch for the fuel pump are back there on the CIS.
Similar one for the AAR. I was thinking WUR due to location on drivers side where he indicated it was found.
Dennis
Old 04-06-2012, 05:41 PM
Wires for the safety switch should be brown/black.
Yes - the location is not where I would expect it either - but it is disconnected, and someone could have just laid it in there along the left side.
If it is the CSV, then it would have power only while the starter motor is energized.
Rex
Old 04-06-2012, 06:32 PM
ROW '78 911 Targa
timmy2's Avatar
You're right Rex, I didn't notice the colors of the wires in the pictures. Makes me wonder how well the car starts.
Dennis
Old 04-06-2012, 06:47 PM
Under the plate on the drivers side would be the OxSensor wiring on 80 to 83
Bruce
Old 04-06-2012, 06:52 PM
Car starts perfectly and has for twenty-six years. Now that I think about it, that wiring could be coming from the O2 sensor...
Old 04-06-2012, 06:57 PM
ROW '78 911 Targa
timmy2's Avatar
Wouldn't know anything about that wire on my '78
Dennis
Old 04-06-2012, 07:03 PM
NeedSpace's Avatar
My guess would have been to the WUR as well as the connection looks the same. Interesting, I have the same issue with my 2.7 with a strange connector that appears to be in the same location (the 3 port item on the bottom left).
After a lot of emails and investigation:
a) many (if not all) have the SAME connector that is not connected on their 2.7
b) no one can tell me what purpose it serves.
Perhaps yours is the 3.0 version of the same connector.
Is it possible this connection is meant to connect to some sort of tool that checks timing or engine performance or something? Maybe a primitive version of the modern auto scanner connection?
Old 04-06-2012, 07:11 PM
howard freeman's Avatar
The wire was most likely added to power a frequency valve for a feedback system in order to pass emisions regs when it was imported. I assume someone spayed it & went back to original. Probably whats left over from a Johnson Box.
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 04-06-2012, 07:33 PM
Needspace - that 3 prong plug looks like the old external voltage regulator plug. Do you now have an internal voltage regulator on your alternator?
Rex
Old 04-06-2012, 07:53 PM
The single wire in my photo comes from the O2 sensor and is spliced into this connector to nowhere. The entire "harness" comes from the front of the car...
Old 04-07-2012, 01:37 PM
NeedSpace's Avatar
Walter,
Hmm, interesting. My car is a 1976 and my engine, while not original is also a 1976. Honestly, I am not sure if I have an internal regulator or not (my car isn't running yet), I assume its an internal regulator as I don't have any wiring left on the engine that isn't connected. I thought the external regulator connections were flat, not circular. Here's a better picture. Interesting though as it is the best guess I have heard, it makes sense and it is where it should be.
Old 04-07-2012, 07:00 PM
Originally Posted by NeedSpace View Post
Walter,
Rear window defroster connection.
H.
Howard Freeman
Old 04-08-2012, 05:12 AM
