Unhappy Clutch Helper spring problem
Has any one had any problems with the clutch helper springer sliding off it's post? My car is a '77 Carrera 3.0 with a '86 915 tranny. It does it it no particular pattern, but seems tight as I pry it back on.
Alan Poh
'77 Carrera 3.0
Old 04-30-2002, 08:56 AM
Senior Member
Superman's Avatar
I think the helper spring is pressed on, so it makes sense that it is going on tight.
Mocha 1978 911SC. "Coco"
Old 04-30-2002, 09:05 AM
Chuck Moreland's Avatar
The helper spring at the pedal is held on by the spring's tension and a little ridge the prevents it from slipping off.
It should be very tight. In fact it should be hard to re-install when it slips off.
Could be your spring has gone too soft and is slack? They're not very expensive to replace.
Chuck Moreland - elephantracing.com - vonnen.com
Old 04-30-2002, 09:21 AM
Smile
I guess I wasn't to specific. I am talking about the one on the bottom of the tranny
Alan Poh
Old 04-30-2002, 12:04 PM
there's supposed to be a washer and a tiny snap ring to keep it in place.
206 637 4071
Old 04-30-2002, 01:07 PM
Bill Verburg's Avatar
Here's a pic of what I did on my 76 Carrera 3.0 w 84 trans;
simple, clean, no nonsense
Bill Verburg
Old 04-30-2002, 01:09 PM
