Triangle of Death Shopping list
OK. I know this has been discussed ad nauseum, but I did a search and did not find what I needed.
I have the engine out, and am resealing as much as I can. For the "Triangle of Death" I currently have the thermostat O-ring, and the gasket for the oil breather. What other parts do I need to complete this top section? Thanks so much.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
oil pressure sender (for warning light, not gauge)
oil breather hose, unless yours is still supple I'd also do the oil cooler o rings (3) as they are cheap and job is easier with engine out
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
![]() And you should replace the vaccum lines. ![]() Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Good stuff guys, I already did the vacuum lines two years ago.
And I appreciate the suggestion on doing the oil cooler o-rings. I have the two, I will search to see what the third is. Is it OK to do this, or is it one of those things where "if it isn't broken, don't touch it". Thanks so much.
French Import
How are your fuel lines?
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Replaced three years ago. Good call!
But I sometimes wonder if they really get bad with age? I guess it is a better safe than sorry call. My tech was insistent on that one.
AutoBahned
they do - be sure you have the fuel hoses clamped with something that will not bite into the rubber
be sure the fuel hoses are rated for ethanol mixes how old are your tires & brake hoses? motor looks pretty - it'd be a shame to run it and get it all dirty... |
Not mine. I'll put up a picture soon.
Good thread, lets get a proper list together.
So for an 85 Carrera I have ordered the following: oil pressure sender -> 911-606-230-00-M85 Engine Thermostat O-Ring -> 999-707-314-40-M17 oil breather gasket -> 930-107-791-02-M17 Would like some advice on the following... oil breather hose -> There seem to be a few options. Also from the picture above, the red plug is the sender, which is the black? |
Wer bremst verliert
The black is a temp sender.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Location: behind the redwood curtain, (humboldt county) california
Don't forget the fuel/return hoses under the tin
The fuel and return hoses were routed directly under the exhaust heat exchanger dump. This caused the unwanted (dumped) heat to bake the fuel lines and when i got home on the cars maiden voyage, (550 miles) i had an ongoing fuel leak.
The hose was not quite charred but definitely badly heat damaged. Sorry, can't find the photo. hth, chris |
Totally good thread. I really appreciate the answers. Now I can prepare my list with confidence. I do not want to have to do this again any time soon.
here is my list while doing a clutch job, the trinity (good parts, it does make a difference), I had to use the green "O" ring on my oil thermostat to keep it from "weeping". I also had issues with my vent hose until I replaced it. Look very close between trans and engine for wetness, now is the time to replace flywheel seal, it is amazing where the oil ends up if this is leaking, very confusing. Again I suggest strongly good parts, I know of what I speak, I had to do it twice, use our host or Porsche parts.
Regarding the Flywheel seal. If I don't see oil leaking, should I leave it alone? Or is it best just to replace it while the engine is out?
If it is not leaking that is going to be a "gut" call on your part. How many miles? I think if it were me I would, the part is not exspensive, mostly labor. You know the slippery slope of "while I'm in there".
PS- CCM911, when my new flywheel seal from local parts store was leaking I thought it was the cam boxes or rocker shafts were leaking, that is why I said it is amazing where the oil ends up when this seal is leaking. By the way I know many will not believe this but I have a leak free '84 Carrera, seriously.
Mo money = mo parts
Not to worry, it's a temporary condition. As the saying goes, "if there is oil in it, there is oil on it."
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
we're calling this the "triangle of death" now? hahha..bit dramatic, dont you think?
anyone mention new axle hardware yet?
poof! gone |
And I got "Triangle of Death" from prior posts. Personally, after seeing how dirty mine was, I am tempted to call it the "Triangle of S&!T".
