matt gineo's Avatar
Started right up after long 18 year hibernartion!
We'll I finally turned the key and my 1976 Targa 2.7 started right up and ran very well (at idle) I only ran it for a few minutes then let it sit for awhile, started her up again a little later to run a few minutes more. She sounds great, a little smoke at first then cleared up. Good oil pressure and no strange sounds or oil/fuel leaks.
Will check brakes next, replace brake lines and tires then take it out for a spin around the block at higher Revs.
I want to thank everyone who helped me along the way, I surely saved lots of time and $$$ with all the great advice that I received on this forum.
This is what I have done so far.
1. Removed fuel tank and thoroughly cleaned out 2 inches of Gooey sludge.
2. Replaced 5 blade fan with 11 blade fan.
3. Replaced Battery
4. Checked Electrical System, replaced all fuses, cleaned fuse terminals
5. Replaced Injectors, Injector lines, o-rings , insulators
6. Replaced Fuel Pump, Fuel Filter, Fuel Pump Relay, Fuel Lines,
7. Replaced Fuel Accumulator
8. FD & WUR Rebuilt by Larry @ CIS Flowtech
9. Replaced points, plugs, rotor, cap, wires etc. Set ignition timing
10. Checked fuel pressure and vacuum leaks.
10. sprayed MM oil in cylinders, let it sit for awhile then turned engine over after disabling fuel system.
11. Set valves and replaced valve cover gaskets. Covers not warped.
12. Checked Head Bolts, looked OK
13. Changed engine oil and filter and gearbox oil
14. Installed pop-off valve,new airbox straps and air filter.
15, Installed Carrera Chain Tensioner
Compression was a bit low on one cylinder before I started the engine and hopefully it will get better after it runs for awhile. Checked inside cylinders with a scope, didn't
see any corrosion or pitting.
Still have a ways to go but I hope to have her on the road soon!
1976 911 Targa 2.7 CIS
Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior
1963 356 SC- crashed
1962 356 C- sold
1965- 912- sold- fun but too slow
Old 04-18-2012, 07:03 PM
tazzieman's Avatar
Well done! Geez that's a nice colour!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 04-18-2012, 07:05 PM
matt gineo's Avatar
Thanks Michael
1962 356 C- sold
Old 04-18-2012, 07:14 PM
Send a message via Skype™ to Porboynz
Brilliant work, a stitch in time saves nine
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 04-18-2012, 07:23 PM
John W
You should be very proud of your accomplisment. Good to get another old one on roads again. Enjoy!
John
89 3.2 Targa 123k miles
Old 04-18-2012, 08:09 PM
Dang! I think I'm getting all moist........
73 911 T MFI Coupe, Aubergine
Old 04-18-2012, 08:22 PM
pete3799's Avatar
Great job.
Keep up the good work.
Pete
79 911SC RoW
Old 04-18-2012, 08:38 PM
Hydrocket's Avatar
Great story...and LOVE the exterior color!
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot....
Old 04-18-2012, 08:40 PM
winter
Winter's Avatar
Nice!!!!!
Looking forward to the "first drive" post!
Old 04-18-2012, 09:08 PM
drola's Avatar
very inspirational. i'll be cranking up a 68 912 with a 911L motor soon. it's been sitting for 15+ years and i'm pretty much going through the same process minus the cis (carbs instead).
the oil was sludge. and i mean thick.
redoing the entire fuel system, entire brake system, ignition, etc etc.
keeping my fingers crossed. otherwise the car is beautiful.
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
2014 Ram 2500 Cummins
Old 04-18-2012, 09:53 PM
Bandwidth AbUser
Jim Richards's Avatar
Congrats Matt! Great looking car.
Jim R.
Old 04-19-2012, 05:33 AM
KNS KNS is offline
Gorgeous car - love the chrome trim!
Kurt
Old 04-19-2012, 07:48 AM
Dublinoh's Avatar
That is a very pretty Targa, agree that the chrome and Targa bar complement the color and Targa configuration well. Nice work.
Old 04-19-2012, 07:58 AM
matt gineo's Avatar
Thanks, I really like the trim as well, I guess it was an original factory option but not too many have survived over the years. The fender trim is in perfect condition, not a single scratch or ding.
1962 356 C- sold
Old 04-19-2012, 08:15 AM
matt gineo's Avatar
Originally Posted by Winter View Post
Nice!!!!!
Me Too!!
1962 356 C- sold
Old 04-19-2012, 08:28 AM
Josh D's Avatar
Trying to think of an adjective that hasn't been used yet, but.....
What all the others have said!!
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 04-19-2012, 08:30 AM
Chain fence eating turbo
Impressed with the thoroughness of getting everything in working order before firing up, I sometimes lack the patience.
That is why it went so smoothly.
I bet that cylinder will come around with some high-revs!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 04-19-2012, 09:40 AM
matt gineo's Avatar
Thanks, I hope you're right, I'm pretty confident it will come up too.
1962 356 C- sold
Old 04-19-2012, 09:57 AM
Very nice. I have a '74 911 that's Gazelle metallic ( another unique 70's color) and go to Newport all the time. I will be on the look out for your car.
Old 04-19-2012, 10:06 AM
matt gineo's Avatar
let me know next time you get to Newport, would like to get together and swap stories. Where do you keep your car?
1962 356 C- sold
Old 04-19-2012, 10:11 AM
