Born to drive a Porsche
dany911's Avatar
Need help to remove a switch.........
I have to change the fog light switch and I have no idea how to remove it without removing the dash cover.
Is there any easier way to do it????
please help me
Rennsport / PCA Region
Porsche 911 Carrera 3.2 1984
Ford Edge SEL 2012
Volvo S60 AWD 2.5 turbo 2006(SOLD)
Jeep Wrangler Off road 2002 (SOLD)
Old 04-21-2012, 11:28 AM
fred cook's Avatar
Fog light switch
I believe that you can get to it from the trunk. Of course, there are likely to be several things in the way before you can actually remove it. I don't believe that removing the dash cover would help. Besides, you would have to pull the windshield to remove the dash cover!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 04-21-2012, 11:36 AM
dany911's Avatar
I know...that's my problem, I have just installed the windshield and I found this morning that the plug failed
I will try from the trunk but there is allot of things on the way...
Ford Edge SEL 2012
Old 04-21-2012, 11:42 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 from the trunk, you have no choice, removing the dash will not help.
got to remove the air box and air scoop
Take carefull note of wiring connection before replacing.
'85 Carrera Targa
PCA/POC
Old 04-21-2012, 11:43 AM
dany911's Avatar
So I don't have any choice....
Ok , let's start it from the trunk..
And thank's for the wires ,I will note and take pictures just in case before to unplugged.
Ford Edge SEL 2012
Old 04-21-2012, 11:48 AM
j930's Avatar
i pulled mine by just moving the center air conditioner outlet over, removing the clock and putting your hand in and you can grab the back of the switch. you probably don't need to move the air duct as i was already in there form the other side and had it all loosened.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 04-21-2012, 11:59 AM
dany911's Avatar
MMmmm!!! that's a good idea, Let's start this way first ..
Thanks j930
Ford Edge SEL 2012
Old 04-21-2012, 12:03 PM
dany911's Avatar
EXCELLENT '!!!!!
Thank's j930 . the access is perfect
Ford Edge SEL 2012
Old 04-21-2012, 12:12 PM
