-   -   its that time for a new set of spark plug wires any suggestions? (http://forums.pelicanparts.com/porsche-911-technical-forum/673799-its-time-new-set-spark-plug-wires-any-suggestions.html)
PabloX 04-25-2012 04:11 AM
Originally Posted by rusnak (Post 6709761)
Just make sure you use the wire holders and do not cross-wire them out of firing sequence.
Thankfully, the two little stickers in the engine bay that show firing order are quite helpful here, plus the Bosch cap is labeled as well.
JJ 911SC 04-25-2012 04:34 AM
Originally Posted by poorshe911 (Post 6708786)
A set of Clewett from our host are fine.
+1... and it add some color but had to slightly enlarge the wire holders with a drill.
http://forums.pelicanparts.com/uploa...1335353651.jpg
kinein 04-25-2012 05:05 AM
http://forums.pelicanparts.com/uploa...1335355496.jpg
http://forums.pelicanparts.com/uploa...1335355504.jpg
http://forums.pelicanparts.com/uploa...1335355511.jpg
mclmk8d 04-25-2012 05:08 AM
Magnecor KV85s
http://i291.photobucket.com/albums/l...d/IMG_0264.jpg
kinein 04-25-2012 07:52 AM
so what are the thoughts of clewett vs. beru?
kinein 04-25-2012 07:53 AM
and how are the clewetts fitting any cutting drilling stretching or whatever problems with installing them? vs beru?
kinein 04-25-2012 08:06 AM
now would you go stock or aftermarket at this point? i know cost is $80 different but thats not a concern i want plug and play not drill cut then try to fit. any thoughts?
PabloX 04-25-2012 08:45 AM
I'd say you want the Berus then. Plus, the Berus (at least the old ones I pulled out of my car) are labeled with which cylinder they go to, which is handy.
rfuerst911sc 04-25-2012 04:08 PM
Fit great on both motors. I went with black so they look fairly OEM.
cmcfaul 04-26-2012 11:34 AM
I have owned a bunch of different one. The red Magnecors are, by far, the best. Getting the other brands on and and off the plug can be a PITA as they are slippery. The Magnacores have tab on the end that completly eliminates any issue.
Bottom line, they fit better than the others I have tried.
Chris
73 911 E
81 SC Ray 04-26-2012 11:48 AM
The ONLY plug and play set of wires is the Beru's. No drilling - no new ends - no poblems. They were good enough for Porsche - therefore they are good enough for me.
stlrj 04-26-2012 02:12 PM
But are they attention blindingly bright red?
Hugh R 04-26-2012 03:17 PM
This may be heresy, but having owned British trash, I think a p-car engine is mostly boring to look at, especially a stock one from the 80's you really can't see much. An older one, or when with all the crap on top of the engine is missing and a nice set of Webers, that is a different story. Why do some people polish/anodize their fans? Its about the only thing you can really see.
Carl83911 04-26-2012 03:23 PM
Beru wires ...
The originals lasted 25+years. That for me is a testament of their durability and quality.
None of the aftermarket ones i doubt will ever last as long as Berus.
Besides, most aftermarket are modified to use Beru ends. Beru connectors fit best.
Buy OEM.
Note: make sure you get the ones NOT "Made in China". The ones made in France or Germany are best.
gtc 04-26-2012 03:38 PM
Magnecors are made in America.
You guys really think that in 25 years, the spark plug wires have never been changed by a previous owner? Do YOU intend to leave those new Beru's on there for 25 years?
gtc 04-26-2012 03:42 PM
Also, the thread-on Beru connectors are crap. Why do you think there is a market for used ones? Hint: Because they fail all the time.
81 SC Ray 04-26-2012 03:47 PM
31 years - no connector failure.....
kinein 04-27-2012 07:49 AM
who makes orange plug wires?
kinein 04-27-2012 08:18 AM
forget the orange they will get dirty i need functional more then looks. i will be installing my supercharger so just need good plug wires. leaning towards beru but magnecor has me from actually doin the purchase still on the fence
kinein 05-03-2012 10:38 PM
so i finally recvd. my beru wire set, bosch cap and bosch rotor and what a difference WOW
