-   -   its that time for a new set of spark plug wires any suggestions? (http://forums.pelicanparts.com/porsche-911-technical-forum/673799-its-time-new-set-spark-plug-wires-any-suggestions.html)
kinein 04-24-2012 12:54 PM
86 911 3.2 mostly a daily driver its time to change the spark plug wires any suggestions?
poorshe911 04-24-2012 01:36 PM
A set of Clewett from our host are fine.
rfuerst911sc 04-24-2012 02:18 PM
I have Clewett wires on both of my 3.0's and they have held up well. Good fit and price is reasonable and agree buy from our host.
kodioneill 04-24-2012 02:43 PM
Like they said.
kinein 04-24-2012 02:47 PM
what about the beru wires?
Targalid 04-24-2012 03:03 PM
I bought Magnecors from our host. They also work well. I had OEM Beru wires with the braided metal sheath. They were old so I do not fault them but they gave quite a light show in the engine compartment. If your current ignition wires are old, as in 26 years old, you might do the visual test in total darkness with the engine running and the engine lid open. Just see if there are any light shows playing in your engine compartment. I think any of the wires mentioned in this thread are good if they are new, Clewitt, Beru or Magnecor. Some people on this forum buy the ignition cable in bulk and fit proper ends on them. That is supposed to be cheaper. I believe I read that the old cable ends, if undamaged, can be reused with new ignition cable.
kinein 04-24-2012 03:09 PM
i rather plug and play. i am goin to do the light test tonite see if i get a light show they are old
rnln 04-24-2012 03:12 PM
how about DIY and do it with bigger size? Is bigger better?
kinein 04-24-2012 03:37 PM
any ideas
kinein 04-24-2012 03:47 PM
so bigger wires? what brand?
rnln 04-24-2012 04:12 PM
I am throwing up a question to see if any response. On other cars I had, many get bigger wire and claimed better performance.
81 SC Ray 04-24-2012 04:14 PM
Beru's - perfect fit, perfect look, perfect performance - after all, how long have the ones you got lasted.................
Ray
kinein 04-24-2012 04:45 PM
i bought this motor with 62k on it. they have been sitting around for awhile so i guess if they are original 26yrs ill take a pic of them when i get home
llangston1 04-24-2012 06:15 PM
I changed out to some red Magnecores from the host last fall and they work fine.
PabloX 04-24-2012 06:41 PM
I just put red Magnecors (as well as a cap and rotor) in my '86 this past weekend. I finished on Sunday and it was raining, so I haven't even had a chance to drive the car since.
Purely from an installation standpoint, the Magnecors are a minor PITA. First, if you want to reuse the OEM wire holders, you'll need to drill them because the Magnecors are thickets. This was easy. The part I didn't like was that the lengths on the wires weren't quite right. A couple were just right, a couple were a bit too short and a couple were a bit too long. I made them work but it made routing them more difficult that it should have been.
slow&rusty 04-24-2012 07:06 PM
KV85 Magnecors
DWeg1998 04-24-2012 08:50 PM
I just put the Beru's in last weekend. My decision was based on aesthetics as I liked the stock look of the black wires, wire covers, spacers, and brackets. And my old plastic bits were cracking into pieces.
Installation took a while as I learned that the AC compressor had to come out to route them in the factory location with stock brackets. But everything fit perfect since I was replacing with the identical wire.
Hydrocket 04-24-2012 08:53 PM
I have Magnecors on mine...
kinein 04-24-2012 09:13 PM
i think i am leaning towards beru. i did the light test i see a little light show
rusnak 04-24-2012 09:23 PM
Just make sure you use the wire holders and do not cross-wire them out of firing sequence.
